Very nice. You didn't go to the extent Guy did but a reasonable scenario, much more likely anyway. Your review was very good and much appreciated, very informative with some intellect behind it.
Yeah, no WAY I was repelling down a cliff-face, however short
Since the purpose was to pry off a chunk of wood, I saw no reason to attempt to flex the blade to the limits of elastic deformation, instead flexing only until I considered the force excessive, then withdrawing the knife and re-inserting it into the wood at another point until the grains of the wood let loose. I didn't want to lay my entire weight into the blade only to have the wood fracture suddenly and send the knife flipping out with the potential to do serious harm!
It may not be evident in the video, but the knife flexed quite a bit with the leverage, much more so than the Bravo 1 would have due to the amount of support material (evident in the cross-section). Regarding the material properties of these steels, however, their lateral tensile strength (UTS) doesn't differ much at the same relative hardness. A-2, CPM-3V, M390 - at the same cross-sectional area and level of integrity, all three should be able to handle about the same amount of lateral force prior to deformation or fracture. Impact toughness (where A2 and CPM-3V are superior) doesn't factor in. The hardness and matrix composition inform where the elastic limit is and how the material will respond thereafter, and all of these will have been back-tempered to relieve stress in the matrix. What this means is that the CPM-3V blade is not superior to the M390 blade in these conditions. What Guy did with the CPM-3V he can do with the M390. Until you bring impact shock into the scenario, CPM-3V will not show superiority. But if anyone has information to the contrary, please correct me on that.
So why did Guy's GSO-4.1 perform better than the BG knife? A few factors may be involved.
1) Cross-sectional area of the BG knife's tip (hollow-ground, iirc) is probably thinner than the GSO which is fairly robust. This is the simplest explanation and is easy to test (if someone has a BG knife on hand). The Gerber LMF & Prodigy would perform better.
2) Steel quality - It would be interesting to see how much force was required to
bend the BG knife's tip prior to fracture or if it gave way without significant bend. If the latter is the case, it is possible that the matrix was either too hard (stressed) or of low integrity, i.e. inclusions or micro fractures already present that propagated upon stress.
As a side note, Gerber's lifetime warranty will probably cover that BG knife. *shrug*
