chiral.grolim
Universal Kydex Sheath Extension
- Dec 2, 2008
Not to sound critical, but impact toughness is certainly an important factor to consider in any cutting tool where media hardness can vary substantially, e.g. outdoor activity. The material property is given a value via controlled experiment, yes, but what the values predict is how the steel will perform when users apply energy into the blade and that energy is rapidly dissipated against a cross-sectional area - this is important because knives with good cutting geometry tend to have minimal cross-sectional area in the edge, making them very susceptible to impact fracture, resulting in chipping along the edge. In situations where the energy is dissipated slowly, strength (UTS) is key as that helps identify how much strain the blade can take in one direction or another before permanent deformation or brittle-fracture occurs. In knives, the concerning direction of strain tends to be lateral where the metal is thin, providing less support against side-loads and resistance to deformation - wavy edges that could later chip-out or indentations result. Indentations could also result from downward cuts where the edge lacks sufficient material support against a hard material, resulting in flat spots along the edge. A thicker edge & harder steel resist such deformations (hardness is directly related to strength).Try not to get too hung up on marketing talking points. Most of this is going to come down to heat treat protocols and not exclusively the rockwell number. When you read the word "toughness" in their literature, read that as impact toughness. They measure how hard they can hit it in a controlled way, before the metal deforms or fractures. That's kind of a non issue with a blade this small. I'll take everything you guys are talking about into account before making a final decision. If I believe it won't be suitable for this application, trust me, I won't use it. I will say I do have a conservative optimism though, regarding this steel.
But if, for example, the knife is dropped, or thrown, or struck with/against another material, energy transfer occurs very rapidly and steels behave very differently than their UTS values anticipate. If, when cutting, the blade slips or encounters a hard staple or bit of rock, impact toughness comes into play. A steel with low impact toughness may chip where one with high impact toughness will not. Again, impact toughness concerns not just the entire knife where catastrophic failure is a concern, it also concerns the tip and edge of the knife where a lateral load can be distributed against a very small cross-sectional area.
Here is a PDF from Phil Wilson on the matter: http://www.seamountknifeworks.com/articles/Knife_steel_impact_toughness.pdf
Now, all that said, one should take into account the relative toughness of various steels and different hardness: http://corse76.altervista.org/col.php?noti2=resilienza
As point of reference, ESEE uses 1095 @ ~58 Rc which has impact toughness ~30 J/cm^2.
M390 has impact toughness in the 30's even @ 63 Rc! It's tougher at 60 Rc, and at that hardness, M390's edge-retention as wear-resistance is among the best of any steel available: http://www.bladeforums.com/forums/s...based-on-Edge-Retention-cutting-5-8-quot-rope
In summary, I definitely think that impact toughness is an issue with ANY knife blade, regardless of size. But the toughness offered by these steels is sufficient for most tasks even at very (read 'ridiculously') low edge-angles and offers wear-resistance beyond what most users would ever need and may ever have experienced....
I have NO problem with M390 in an outdoor knife... I just hope that my wife and my wallet don't have a problem
