Murphjd25
- Apr 27, 2016
You just solved the CP4 problem!!!!!!It's good for applications where you need a combination of strength, toughness, and wear resistance with decent corrosion resistance. It wouldn't make sense to use it on something like leaf springs.
Poor heat tolerance, so it would not work well on things like valves and valve seats.
It might be a good material for the CP4 fuel pump swash plate?
Suspension component joints. Parts in the steering column. Moving parts in the doors and latches. Anything that you want to never break or wear out or rust too bad.
