I don't know what that has to do with the recycled vs. new steel debate but a lot of guys make drop hunters for one simple reason; They SELL.
OK Kevin here goes...
Lets start out with,do you know if it is a stainless steel or carbon,Stainless will barely pull a magnet...
...Have you tried a simple quick oil quench after heating to non magnetic...
...Now forge the blade to your desired shape...lets normalize the bar 3 more times and let cool to room temp to relive any stress caused by forging....
take the blade to the grinder and shape it then do about half your grind on the blade and polish out to about 400 grit...
... now after the third normalizing heat is cooled down bring the blade up to non magnetic and quench...check the edge with a new file,it slid across the edge ,great, now put it in the oven at 350 for 2 hours,if the edge is to hard for the file to just grab in bump the temp up to 400 and try it again,if this is still not soft enough bump it up again at 25 degree intervals untill you get the edge were you want it....now go finish the knife and do some cutting see if it works good or great or doesnt hold a edge ....Now find some known steel and try it and compare the 2 and see if you want to keep using found mystery steel or known...Good luck in your project and if you hve anymore questions just holler and I will see if I can help out any more...
Bruce....
First- Do you folks who enjoy remaking old articles into knives consider the idea that modern steel alloys are countless variations in chemistry, each with their own specific heat treating requirements, False?
Second- Do you find the idea that using exact times at temperature along with precise quenching methods according to the specs are simply unnecessary over-thinking, when one simple recipe such as heating to nonmagnetic and plunging into oil will get the same results?
If you sincerely answered yes to both of the above, have you seen information to the contrary or would you be willing to allow me or others to give some information as to why the answers could be different, and in the process give more information in support of your position?
Tai,
I would be very interested in your ANSWERS to Kevins questions.
Del
Henry David Thoreau contrasts the approach of two fathers to their sons education.
One sends his son to the university to learn the science of metals and upon graduation gives him a Rogers Pen Knife.
The other lad decides to make his own knife, mines his ore, smelts his steel and develops his own knife.
"Which one is most likely to cut his finger?"
We all had to start somewhere, most of us had no instruction at first, but made many knives and if we tested their quality learned what worked and what did not work.
There are no dumb questions, I will answer any who ask.
...There are no dumb questions, I will answer any who ask.
When these threads get this contentious, it becomes all too easy to misinterpret the words written.
Would you folks indulge me with a little exercise? I promise that this is not meant to inflame the situation or belittle anybody but to help clarify where ssome of us are coming from, which seem to be a bit unfathomable to some. Here it is:
I have a piece of steel here. It is a very nice bar that is not too far from knife dimensions. It has a bit of rust pitting on it but I cleaned most of it off and it sparked differently than any of the low carbon steel I have, nice umbrella shaped bursts. I know how to forge and grind it; after all shaping techniques are pretty much irrelevant to the type of steel. How do I properly heat treat it? What is the appropriate soak temp? What quenching medium should work best, air, oil or water? What hardness can I expect, and what tempering temperatures should I use?
Now telling me to test it out myself and is just a cop out since I came here asking for that information from you and I would hope you would be willing to help me, sending me away may be interpreted as disdain for my question or choices.
If you feel the best thing to do is to tell me I should know my steel better myself I will understand, but I would really like you to help me if you can. How about it?
Perhaps we need another thread specifically for how to find suitable steels, analyze, research, test, use, and get the most out of salvaged and recycled steels,... rather than whether or not we should.
Once again we are getting side tracked, perhaps because I wasnt specific enough as to whom this thread was addressed but we have subsequently focused on the more experienced guys using scrap; I see self professed steel snobs, I see proud recyclers, but I seen very few self proclaimed newbies here. every year as long as my guests are still talking to me![]()
