- Feb 28, 2002
You are the one making attacks. I am merely pointing them out. If you wish to make the conversation productive, you must be productive.
Can we come back to three ways of looking.
Normal reasonable use
Destuctive Testing
Abuse
Normal use of a tool will not damage it.
Destructive Testing is destroying on purpose, you are doing this for the express purpose testing to find where the tool breaks.
Abuse is extending normal use knowing that you might damage the tool.
Can we seperate Destructive Testing and Abuse?
A tester breaking a tool is different from a user breaking a tool.
Can we seperate Normal reasonable use and Abuse?
Normal reasonable use is actually set by the manufactuer and their claims, and their warrenty.
So Brand A sells their knife with claims of 'unbreakable', then they have moved the definition of reasonable use
No, we can't.
Why not?
Can you answer this?
When you do, you can clarify your argument.
You propose that reasonable usage is the way to test, and you are against destrutive testing as abuse.
Destuctive Testing is a normal method of testing.
We can call it abuse with a purpose
Which is different from abuse without a purpose
This point is actually the crux of your whole discussion.
Your answer is pivotal
You will get the respect you offer.
Then please respect my question
and post an substantive answer
Thank you
Waiting
Destructive "testing" of the type I'm decrying doesn't provide meaningful insight into the answer of that question. There's simply no way to know if the conditions you face will mirror those that broke the knife, unless it's something obvious. To say, "I hammered this knife through a cinder block and it broke" is fine and good, and if you expect to encounter cinder blocks in an emergency, I suppose that is relevant. Otherwise it really is not. To evaluate a knife as a tool, you look at what it is designed to do and what it is intended to do, and then you evaluate how well it accomplishes those goals.
When you deliberately abuse a tool, the assumption you should make is that it may break when you do that. Every time you pry open a paint can with a pocket knife, for example, you should acknowledge that the tip of the blade may break off. That's simply the assumption of risk that you assume.
There are very few real survival situations that would require you to something truly Herculean to a knife, such as hammering it through a brick wall. If the issue is whether the knife can be batoned without breaking it, and that is really a huge concern to the owner, it would be better to carry a small hatchet in conjunction with the knife. All of this planning presumes you'll have either tool in the aforementioned emergency anyway. You can't predict every tool you'll need, but you can provide for the basics such that you don't have to risk abusing a needed tool.
There are people who put too much enphasis on tests like these, but there are also mall ninjas, steel snobs and all kinds of different points of view. So what?
The screw driver as an example is the most misused tool in the tool box. It's designed to insert and remove screws according to the shape of it's head "and that's all". Yet it's used as an ice pick, scraper, wood chisel, pry bar, paint can opener, for punching holes in drywall, drift pins and the list goes on...... So the kinder gentler review following the manufacturers designed purpose would depict it inserting and removing screws and that's all. The kinder gentler test fails to provide all the information about the tool. To really know the tools limits you have to stress it which includes to the breaking point....
Ahhh! Now we're getting somewhere- I'm glad I checked back.
I agree that some of the tests (hammering through a cinder block) done in isolation really wouldn't provide much meaningful information. I think the value comes in when you put different "hard use" knives through the same tests, and some break and some don't.
As you point out, there really isn't much chance that anyone will have to chop through a brick in a survival situation, but then again, the target audience for this type of knife is looking for a knife that will be up to whatever unforeseen circumstance they find themselves in. It may not be chopping through a brick, but now you know that this particular knife can withstand that kind of use (abuse?) and that particular knife can't.
This is very true, and I think, when the test subjects are "hard use" "survival" type knives meant to be an individuals lifeline tool in any desperate situation, then these kind of tests are called for. Anything less than finding out what breaks the knife does not answer the question of "just how far can I trust this knife?" I am assuming that all the knives cut and hold an edge to a reasonable degree.
I think that's the point- you can't predict! People are looking for these knives to be THE tool that will provide for their needs.
If it does turn out that tests like these raise expectations, is that necessarily a bad thing? Look at the performance of some of these blades! Not just the Busses, but who would have thought a Cold Steel Bushman would do so well? I had always thought of them as cheap novelties.
You are absolutely right that some people may use these tests to demean otherwise worthy knives- I love my Dozier Gentleman's knife, it is one of the best slicers I own- in spite of the fact that it would never pass one of these tests. But then, it was never advertised as a tough, hard-use knife.
This is a great example....the Chapman Gun screwdrivers are generally regarded as some of the finest U.S. made precision gun screwdrivers in the world. They are a purpose built tool....the brochure specifically states that they are NOT designed to pry, open paint cans....they are made to tighten and loosen screws....they are expensive....by much of the reasoning demonstrated in this thread, does this make them inferior to the Chinese or even domestic made screwdriver that can handle all of the above activities without any damage....but chews the heck out of screws?
I don't think so....maybe others do, but it goes back to Phil's original statements concerning intent of the maker AND the user.
A Chapman screwdriver bit is used for tightening and loosening screws...only.
Best Regards,
Steven Garsson
