hi scara, bawanna - yes, it is very panabas-like, one reason i wanted it. a lot cheaper than TFW's too
i know this one has had a good workout & is still solid, so it should be good for quite a few more
heads, er melons.
it's haft is made of red padauk wood, whatever that is...
my friend says that the original mak i posted was likely hafted in a SEA form of 'male bamboo' rather than rattan or a lesser bamboo, it's a species of bamboo rather than a gender, it was specified by the brits for their lance hafts and is a traditional material for spears, swords grips, maks, and even bows and arrows. it has much thicker walls to the culms (the hollow sections) and the hollow centre diameter is much smaller. makes it a lot stronger but still a bit flexible, bit less so than rattan tho. the root section where the blade is, is solid rather than ahollowed like the culms (stems). rattan is more of a vine and is not hollow.
edited: found this info on padauk wood:
This attractive wood has high strength properties, durability and outstanding stability and is deal for high-class joinery, furniture and cabinetmaking. Also for fancy turnery and carvings, tool and knife handles, spirit levels, paddles and oars, and agricultural implements. It has a high resistance to abrasion and makes and excellent heavy-duty flooring timber, also suitable for floors where under-floor heating has been installed because of dimensional stability. Selected logs are sliced to form very attractive decorative veneers. Renowned as a dye wood.
General Description:
The heartwood is a vivid blood red, toning down to dark purple-brown with red streaks upon exposure. The grain is straight to interlocked with a moderately coarse texture. Weight varies from 640-800 kg/m3 (40-50 lb/ft3), average 720 kg/m3 (45 lb/ft3); specific gravity .72.
Mechanical Properties:
The timber has excellent strength properties especially in bending and crushing strengths, with medium resistance to shock loads and stiffness.
