I just measured and it looks like the lanyard hole on a small Sebenza is exactly 4mm in diameter. Looks like maybe the Higo and Hizen have the same size lanyard hole then? If that's the case, then the lanyard pin from a small Sebenza should fit both. The sticking out on both sides is definitely a function of the thinner liners on the Higo-X compared to the handles on the Duralumin versions.Nope, you've got it right. My Higo and CRK's sport 4x10mm tritium vials. The Rocky has a much tighter fit than the CRK's, and the vial sticks out a little bit on the sides.
From the pictures BluesBender posted of his disassembled Chi, it seems like the pivot screws don't even go through the front scale. My guess is that to adjust the blade you have to take that scale off first. (I think there are some pictures on the 4th page of the thread)My guess is that the pivot screw is hidden under the Stingray insert and that you have to send it back to Rockstead so they can remove it and adjust it. But I must imagine they have it loctited down pretty hard to hopefully prevent that circumstance.
I also want to note that the Shinogizukuri blade on my Hizen still has the 24-30 degree variation in secondary bevel angle. You can clearly feel it in cutting performance at the tip v. at the choil. The reason that the width of the bevel is the same at all points is because the thickness behind the edge increases gradually as you get closer to the tip of the blade to match the angle.
