That's a funny thing to be curious about, as there is virtually no practical use that could come out of that knowledge.
At this point, I will hang onto them for a rainy day. I've had about a dozen people ask me over the years to sell one but it's my favorite Spyderco (tied with the Military).![]()
M390 has a higher alloy load (28.5 percent to 21.45 percent), so I’d expect S30V to be a little tougher, but that doesn’t seem to be the case, although both appear to be close in toughness.
Toughness reduces the tendency to chip, and from anecdotal posts on the forum, S30V seems far more chippy than M390, which would indicate a sizable advantage for M390 in terms of toughness.
According to this chart from simply tools http://www.simplytoolsteel.com/knife-steel-comparison-chart.html
S30v is tougher than m390
Yes, I have a horrible picture. My apologies for the lack of quality. That too is an old outdated photo.
Yeah, they should remove that chart, looks to be utter nonsense, not clear what they base any of the values on :thumbdn:
Does crucible have anything comparing them? If you got any solid info proving otherwise you should contact simplytoolsteels and tell them they don't know squat about steel and there info is wrong lol
Like every other steel chart of that type, it's incomplete at best and almost certainly misleading. Other than sweeping generalities, it really doesn't mean a whole lot more than, someone knows how to make a pretty bar graph. "All grades at 58-60Rc"? There can be very significant differences in almost any steel in that range, and (for instance) comparing D2 at 60Rc to CPM-154 at 58Rc is going to be way, way off from comparing them both at the same hardness.
Spend enough time looking at so-called charts like that and you can find one to suit nearly any "results" you want - whether it makes any sense or not is a whole other question...
See my post just before that one? It contains data sheets from Crucible on S30V and CPM-20CV. It looks like simplytoolsteel took they comparative transverse toughness comparison of S30V and such to 440C and pretended it was longitudinal toughness and kept the same proportions for only those steels, i.e. utter nonsense. Per crucible, S30V and S35VN and CPM-20CV, etc. all present about the same impact toughness as 440C but at a few points higher hardness (which is good, but nothing like what that graph pretends).
Yeah, I wouldn't put too much stock in what the various charts say, or the data sheets for that matter as they don't represent or reference knife blades in the 1st place....
The data sheets represent what the steels were originally developed for, and that's not knife blades...
The sheets are for general reference......
CPM-S30V toughness data (Charpy C-notch) can be had from Crucible, they list it as on par with 440C (~25J) unless you measure the transverse value (which no one does, it's too low): http://www.crucible.com/PDFs\DataSheets2010\dsS30Vv1 2010.pdf
CPM-20CV (Crucible's version of M390) is about the same but at 2-points higher hardness: http://cdna.terasrenki.com/ds/CPM-20CV_DuraTech-20CV_Datasheet_1.pdf
But M390 higher toughness data comes from an EU paper, doesn't use Charpy-C but gives comparative values for Elmax and S90V. http://www.kau.se/sites/default/files/Dokument/subpage/2010/02/26_349_359_pdf_19432.pdf
This might be incorrect but wasn't s30v originally created as a knife steel ? I thought I read it was one of the first steels created specifically for knives?
You seem to have all the info so let them know there chart and steel info is crap and it pretends to be true lol I'm not taking this too seriously kinda seems like you are so if I ruffled your feathers over a chart it wasn't intended..
