Crucible might have shipped bad batches of S30V, but the most likely cause for these problems is poor heat treating and overheating the edge by manufacturers. Read some of the relevant threads on S30V chipping and you'll find this to be the general consensus. Better yet, search for posts by Dick Barber, the Crucible metallurgist who developed S30V (his forum handle is Crompal). He addresses this issue directly in more than one post IIRC.The steel has been out now for 4 years. I really wish someone who knows would inform us as to why this steel causing so many problems. Its like a great big secret or mystery.
First of all, Crucible says S30V "grinds about the same as 440C." This refers to grinding before hardening because S30V is clearly harder to grind than 440C afterwards. Any maker will tell you that it's easier to overheat the edge of a highly wear-resistant steel compared to steels with low wear resistance. Given the same equipment, you have to hold the edge against your belt/wheel longer to get the same amount of metal removal. S30V is one of the most wear-resistant steels that manufacturers use, if not the most.There have been lots of claims made about the source of the problems which make little sense and are contradictory. S30V was promoted for ease of grinding and heat treating over 440C and now both of those are claimed to be the source of the problems even though the exact same asepcts were used to sell the material in the first place. And now we have another from a Crucible rep in that apparently S30V is extremely sensitive to double tempering even after cold treatments. Try to find actual materials data to support that claim.
The two explanations given are entirely reasonable; knifemakers who don't use S30V and metallurgists from other steel companies would agree that these could cause the problems we're seeing with S30V. Feel free to ask them and let us know specifically what they think. Is there some inherent weakness with the S30V formula or how it's made? The scores of well-performing S30V reports speak for themselves.It can't simply be a batch issue either considering the problem continues to this day and has been widespread over many types of knives.
i have yet to have a chip-
they are all edged with my lansky at 25
Well, I think it is time to finally drop the issue how a steel, S30V in particular, was advertised when it first came out. I think focussing on that is extremely unproductive.
Jerry Hossom recently just mentioned that S30V is still labled by Crucible as an air hardening steel, even though it can most certainly NOT be air hardened and produce resonable results.
Ease of heat treating is one thing, getting it wrong is another. O1 is far easier to HT than these stainless steels, you could do it with a torch and eyeball the temps, but if you forget to temper it after quenching and it breaks like glass, are you going to accuse the steel company of false advertising?
I know it does, but I think it is still not very helpful to continue to lean on this. It is living in the past. What are references good for if they are obviously not relevant anymore. Science is about progress, how does it help progress to know how a steel was advertised as? The steel is out for years now, either the steel can offer some real performance or it will disappear. For anyone interested in performance cutlery should be concerned about how to make S30V perform, otherwise it is just a dead end.The claims indicate an issue of contradiction which is very relevant when you are citing references.
-Cliff
I know and in case this came across wrong this is precisely how Hossom explained it as well. Still, apparently some people tried to air harden it (no forced air)...which didn't work. The procedure suggested by Crucible involves salt baths if I understand correctly.Air hardening means the alloying elements will act to prevent the diffusion based pearlite/bainite and thus allow martensite to form. Martensite just with an air cool and are thus by defination air hardening. S30V, is very much an air hardening steel by defination, as is 3V.
-Cliff
Small wonder, that is a profile not even fit for an axe.![]()
The edge can heat up very quickly to hundreds of degrees hotter than the rest of the blade, and you don't have to hold it for an hour to affect the temper. If S30V is usually tempered at 400°F like you said, it would be even easier to overheat the edge. S30V also needs to be held for 2 hours minimum at the temper temp. An overheated edge gives the steel there a short and hot temper (no pun intended). Are you claiming that this doesn't affect the hardness or other properties?Cliff Stamp said:Do you think it is reasonable that someone hand sharpening can generate that much heat or more and hold it for that length of time?
You missed my point. If they had an incorrect heat treating schedule, they would get consistently bad results. The question is not if companies can heat treat consistently, it's if they know how to heat treat S30V properly.The same companies are getting much more consistent results with other steels so that comparion doesn't hold because it implies they would have such systematic problems with all steels.
It's not meant to be an explanation of the "very high defect rates," something I don't agree with in the first place. If it's not the steel itself (as it comes from Crucible), then what is the cause? Poor heat treatment practices and post-HT processing (leaving a coarse finish on a notch-sensitive steel isn't a good idea either). Otherwise we'd be seeing the same "widespread" reports among S30V customs regardless of maker.It speaks for the optimal performance of the steel which was never in contention. It doesn't explain the very high defect rates.
Dick Barber (the developer of S30V), Ed Severson, and Scott Devanna have all posted at BF. They said Crucible is analyzing some of the chipped blades to figure out what went wrong.Has Crucible ever visited us to take on some of our concerns? We are a blade buying population after all.
Multiple tempering is more critical for upper temperatures because there is significant transformation of the austensite to martensite because of carbide precipitation which effects the Ms point and thus induces martensite to form in the cooling after tempering. A single temper then leaves this martensite untempered. However S30V is usually tempered very low around 350F - 400F which doesn't have the same effect on the steel. Nor in general are the results so drastic to explain the performance seen such as steels chipping on carboard, plastic, vegetation, etc. . No one would argue that going from single to double temper, especially with low temperatures would induce such a change in the material properties of the steel.
-Cliff
[overheating]
Those issues are not past HoB, many are in fact general properties of P/M's. As well those same documents still exist and have not been changed so it is still very much being promoted the same way.
-Cliff
