Shouldn't the pivot bushing be smaller? I always thought it was the pivot bushing + washers that should equal the width of the stop pin and standoff?
Sharp is correct.The pivot bushing being slightly taller than the washers is why you can tighten the pivot screw to max tightness. Then the blade actually rotates around the bushing.
Washer/Grease
BLADE
Washer/Grease
The thickness of the sandwich above should perfectly match the thickness of the pivot bushing, stop pin (collar on the 21, shoulder to shoulder on the 31 unless there is shoulder nesting?), backspacer heights.
