rileybassman1
- Aug 12, 2012
Well, this has been a puzzle to figure out this 31. Lol.
So I decided to break down my 31 and give it a great cleaning...for the 6/7th time? I cant even remember.
At the advice ofrileybassman1 I decided to tighten the screws in different orders and managed to get it together with the pivot tight. It was still very tight to open tho. Just not as bad as before...and the terrible lock flex was still there.
Then I had to take a drive...a three hour drive, so I decided I would constantly open and close this 31 all the way down the highway. No flick open, just rolled with my thumb. I figured i would try to break it in and see if the lockup got tighter. Because as I stated in an earlier post, if i physically push the lockbar over another 1-2mm it will lock up solid. So after maybe a low count of 2000 openings and a super sore thumb...my 31 is smooth smooth smooth...the pivot screw did not loosen and is still tight...
However,
It did not fix the flex issue and now I also have side to side play. Smooth, but with all sorts of slight play. If I push the lockbar in another 1-2mm (which is almost 100% lockup) I have solid lockup, no side/side, and acceptable flex (think 21).
So with a regular roll, or even a wrist flick, this 31 will not lock up solidly.
Then I got this idea that maybe with cutting force on the blade, I could get it to lock up further...so I got a piece of hardwood and did some testing. The tests are inconclusive.
Sometimes (usually when i used the heel of the blade and a firm grip), it would go to that full solid lockup. Sometimes it wouldnt.
ETA because i accidentally hit post...
When I used force on the tip of the knife to cut the hardwood, I never achieved full solid lockup.
So very puzzling. I believe lock geometry and tolerances are slightly off...
But honestly, what do I know? Haha.
I'm wondering if perhaps CRK would put in a larger blade stop if that may help us out a little... I'm debating about reaching out to them when all this is over as well.
I disassembled and re-assembled a few more times today (and slightly stripped my pivot screw... argh... need them to open so I can get parts lol) I was able to get the same smoothness every time... I did really notice that if i tighten my pivot to full tightness, followed by the other screws... it is MUCH stiffer (but also more solid side to side)... so those of you that suffer from overly stiff pivots and the inability to get the pivot to full tightness, play with full tightening body screws prior to installing the blade.
Two interesting items of note - first the smaller washer on the lock side - I don't think it's flat... if I have it on one direction, the blade slightly favors the clip side, if I flip that washer around, the blade slightly favors the presentation side. The way it came (favoring clip side) if I tighten the pivot, work the action maybe 30-40 times, it starts to wander more towards the center... so I think something (bushing, pivot, washers?) is not even and either rotates or settles.
second item, the blade play - or what we may call lock rock - feels very similar with the blade partially open - I still get a little clicking noise - now it's not directly the same because as stated above, pushing the lockbar over further does seem to eliminate the lock rock. So... I'm wondering if the pivot/bushing are not completely to speck. I noticed some slightly uneven wear on the scales on the inside as well. I have other knives where centering seems to be dependent on the direction of the pivot.
I know we have debated about calling this lock rock vs lock bar flex... so for me in my situation, I'm getting legit click when i really try and move the blade... so I think, at least for some of us, that lock rock is what we are dealing with... and the lock "flex" is a secondary result of being a frame lock.
I wonder how many people it would take contacting them for them to be willing to try and resolve this...
