So couple interesting items of note:
First, to some above, some of us (not all, hence the ongoing discussion as we are looking for common denominators) are having lock "rocking"... not table-top spine flexing... but 20 dollar walmart gerber clicking type of lock rock as demonstrated here:
https://imgur.com/lZhlPS8
The annoying part - to me - was that this exact video was sent to them and they stated that this was "totally normal"... that is why some of us are still frustrated... and several of us have gotten different answers... from "that's normal" to "that's a feature" to "it's a known issue and we are working on it"... edit to add: with everything going on in the world, I understand that communication etc is tough right now... I just hope to see/hear a consistent response at some point I guess? Either a "deal with it" or "we will look at it" type of thing.
Ok, on to some interesting stuff
I got a "matching" 21 inlay in the mail today and played around for a bit.
First off, the 31's presentation scale will work on a 21... here's proof
Up and down went away. There was some slight side to side - however, I accept that this changes the design the washers were made for... I didn't mix and match any washers or any other hardware at this point... I probably will soon and test some different combos.
I believe that a 21 stop bar will work on the 31 by the looks... I took a bunch of measurements (cheap digital calipers so take it for what it's worth lol).
The blade bushings from the 21 to 31 are identical.
The stop bar bushing and the stop bar from the 21 to 31 seem to be nearly, if not identical - some measurements were exactly the same, some were at most 1/1000 difference, but I attribute that to my own inconsistencies with my micrometer.
So, I think the most interesting find was that I don't think the holes on the blades (at least my copies) are exactly the same... using my expanding caliper side of the micrometer, taking a few measurements they seemed to be the same... however, when I put the bushings (either one) in the 21's blade hole, they are noticeably tighter then when in the 31's blade hole (again both bushings). This is further confirmed by the half open play test (yes, I understand that this can/is "normal" I'm not arguing that point, only reporting findings) the 31 at half open you can feel the slight movement of the bushing... almost a loose click... the 21 at half open - 100% solid - zero movement... so I think it's beyond my tech's ability to detect a circle's inconsistencies... but i'm wondering if that has some bearing... (pun intended lol).
I will play/test more combos in the future, but for now, they are both assembled as built. One item of note - this was probably the "best" 31 assembly this time... what I did was tighten the pivot to where it's super stiff, requires 2 hands to open... I then tightened all other screws... I then loosened the pivot ever so slightly (all pivot adjustments are without lockbar tension... as another stated, the 31 seems pretty touchy to adjustments with the lockbar placing pressure).
The result is 0 side to side play.... but there is still vertical play/lock rock... Maaaayybe ever so slightly better... but still very much noticeable (by hand, not table).
What's all this mean??? I have no clue lol... just reporting findings. Knives are my hobby and this forum has been an "escape" to some of the nastiness in the world lately... I have enjoyed "problem solving" with you all and reporting findings... it's like the colab work I do at time at work lol. I have no desire to fight or have drama with anyone... this is my "fun" place and if it causes more stress I'll limit the time here
I just know several others are on this same ride and I like to report any new additions.
I'm glad most 31s seem to be fine... some aren't... mine's tolerable I think but time will tell... it's beautiful... I know that much
If anyone has any specific questions on the 21/31 stuff lemme know... I'll probably leave them alone a few days and just try to "cut stuff" lol but the curious tinkerer in me will definitely delve in again...
Couple beauty shots - I do love how the micarta on the 31 is wearing in
