- Feb 28, 2011
Wasn't a joke. Maybe not finish, but they're put together pretty well and consistently done so. I've had Benchmades that were rock solid in construction while being smooth as glass, others (and a lot others) that could not be solid with out the action being too tight for my interests in an axis lock. Geometry is there, good grinds... Now in XHP. And DLC if that's ya fancy.
For what it's worth, I'm in agreement. F&F are certainly well short of CRK levels, but CS generally has quite good cutting geometry. I've used a Sebenza more than a bit and the cutting geometry was certainly good, but I've also cut with knives that had better for various tasks. No matter how tight your tolerances and how good your attention to detail stock thickness, grind height, and grind radius/angle are all pretty profound indicators of the results you're going to get. Once those choices have been made thickness behind the edge is the only thing that I've really seen make a profound impact on performance in terms of geometry.
