I'd wish Chris Reeve would chime in.
You're really passionate about this subject.Yep. Browse this one instead:
http://www.18-xray.com/Brouchre/EXTREMA RATIO/files/extrema ratio catalog - january 2010.pdf
Pay particular attention to the description of the RAO on page 27, to wit:
"The result of our research is a knife called RAO; a survival knife that is not a big folder but a compact field knife with a strong, heavy blade and a very safe locking system that is assisted by an extra safe device which transforms the folder into a fixed blade knife." [Emphasis added]
If you see what I see, you just met the folder that the Tri-Ad lock cannot compete with . . . virtually or actually.
No, it was a new knife. Only failed the weight tests.It failed under hand pressure AFTER spine whacking and the strength test..I will also add had those two tests been reversed, the results may well be different...Don't think Demko knew this?
As in math, order of operations.
The RAO is certainly not a knife I'd be willing to carry. But until Cold Steel can prove otherwise, I'm giving the RAO the benefit of the doubt that it's stronger than any knife currently manufactured by Cold Steel that contains a Tri-Ad lock.Isn't that thing like 12 ounces and not exactly convenient to open or close, though (unless I'm remembering wrong, doesn't it have to be assembled after opening by adding a pin or somesuch)?
That said, they did beat on one of those Wildsteer WX knives with the double lock--it did pretty terribly, as I recall, and it had the same sort of marketing "becomes a fixed blade" stuff, so maybe CS will take a stab at the RAO. Then again, maybe you're right and they already did, but they couldn't beat it so the video never saw the light of day . . .
The purpose of a lock is to lock, the purpose of a knife is to cut.
A knife can still be a knife if it doesn't lock.
A knife can NOT be a knife if it doesn't cut.
Mark = missed.
We differ on our preferences. Nothing wrong with that.![]()
No more passionate than LT is that Cold Steel makes the strongest folders on the planet. If he's so sure, let him prove it.You're really passionate about this subject.
All I know is I gave it a real workout.
I carry that exact knife I tested everyday. :thumbup:
I know how to ride a horse. Does that mean I shouldn't buy a car?
And if you had common sense, you'd realize that the best use of any safety system is not having to rely on it at all.
No, it just means that you don't strap a horse and a car next to each other on a stand, hang heavy weights from the tire and hoof and then declare that a horse is a bad method of transportation after you snap its leg.
Well, figure out better lock strength test and report back here. We are all ears...
For me at least, it's the ongoing notion that reliance on the safety feature of the wrong tool is an acceptable substitute for using the right tool instead.
If X can consistently perform Y task without failure due to superior strength or construction why isn't it the right tool for the job? Cuts with lateral torque were brought up and you dismissed that as a job for a fixed blade, but slipjoints have been doing that for years. Heck, the whittler pattern is so named for an activity that involves a ton of those cuts. That's one big reason I don't care for framelocks. When there are tasks that I feel safer performing with a knife that does not have any type of lock rather than a framelock I have difficulty accepting it as good design.
Heck, the whittler pattern is so named for an activity that involves a ton of those cuts..
EDIT: I just looked at that catalog. HOLY BEJEEZUS, and you call Cold Steel mall ninja/tacticool?!
Again:
a) You have to understand that knives are used for more than cutting
b) Lock is a safety feature
c) Knives are also sold to people who aren't "expert knife users"
I have plenty of non-locking folders and I was using them since I was 7, which is almost 60 years. That doesn't mean I can't see the benefit of a locking folder.
There you go good enough for me. In fact I'd trust your tests to show real usage more than cold steel's single minded BS any day. Just like the Zaan I posted showing how tuff it really is.
That doesn't mean safety feature has to be crap if device/tool/system is equipped with one.
It doesn't sound like we have an argument here. As always, it's a matter of matching the tool to the job. Can a whittler whittle? Of course. That's what it's designed to do.
