So I recently was gifted a Spyderco Native 5 in S110V by my father, which is pretty dope, but anyway, I remembered this thread and I wanted to add my own sharpening experience to the mix.
I used Shapton Pro stones which are comprised of aluminum oxide, and for the strop, I used chromium oxide compound as well as bare leather.
The JNS 300 is an excellent stone. Very hard, much like the King 300, but the abrasive density is considerably higher, making it a far faster stone.
I then hit the Shapton Pro 1k. You can definitely feel how much harder this steel is from your average Aus8 blade or something. But converting my scratch pattern was no real issue.
Next was the 5k...
Then the 12k. I really love this stone as a finisher. It's just so damn hard. I often use extreme-grit stones like this or the SG16k to strop off my burrs. It works flawlessly, and they are high enough that 1 or 2 stropping strokes won't effect your specific edge performance. That is, you can sharpen on a 220, strop the burr off easily on the SG16k, yet still reap the performance of a 220 grit edge. It's fantastic. I just recently ordered the Gokumyo 20k (.5 micron) for that same purpose. Very excited. Anyway, I digress. As I said, the 12k:
I was very gentle on this stone, and switched sides a few times. I like to do this just to really make sure I am minimizing that burr as much as possible.
Next up was stropping on chromium oxide on one of the Stroppening strops:
And then some bare leather, extremely gently at a slightly higher angle to really make sure I cleaned that apex up:
And the results were quite standard:
I do have to say, I think a lot of the talk about the impossibility/gross difficulty/poor results of sharpening extreme steels on aluminum oxide are regurgitated information. The steel was obviously more difficult to sharpen than, say, Aus8, or S
30V because the carbide volume is considerably higher
and the matrix steel is harder at around ~62, but I think people tend to forget that the carbide volume in a steel is only a fraction of the entire composition. CPM states in their own literature that carbide volume is anywhere from 5% to over 20% volume, with the implication being that 20% volume is
extreme. Well the other 80% of what you are abrading is merely the steel matrix at about 62 rockwell, which even chromium oxide can easily abrade. So as far as the ability to sharpen such a steel on aluminum oxide, I was completely unsurprised by the results.
Anyway, I just wanted to post my own experience because it does seem to differ rather largely from the generally accepted notion, therefore I think it may add something valuable to the conversation
