Shame that @skblades cannot ID that ePrey seller and refuse to sell to him/her again.It was inevitable, the resellers have found it. $77.30 shipped on a BIN.
It looks like black cherry to me
It was actually pretty easy! Black RIT dye from the grocery store, half a bottle mixed with hot water to fill a Pace Salsa jar. Per the directions, added a few drops of dawn dish soap and a little salt. I degreased the handle with rubbing alcohol and rinsed with water. Opened the knife and used the blade to stick the handle in the dye solution and stirred (not shakenIt looks like black cherry to meif you have time what was the process you used?
Very niceIt was actually pretty easy! Black RIT dye from the grocery store, half a bottle mixed with hot water to fill a Pace Salsa jar. Per the directions, added a few drops of dawn dish soap and a little salt. I degreased the handle with rubbing alcohol and rinsed with water. Opened the knife and used the blade to stick the handle in the dye solution and stirred (not shaken). After 5 minutes I removed the knife and re-heated the dye solution in the microwave and then replaced the handle in the dye. The handle was in the dye for about 30 minutes to get the color I wanted. It’s slightly darker than it appears in the picture. Fun little project I’m sure I’ll try again some other time. Love to see some other people’s results!
I have several Buck knives in ATS-34 and they perform very well. It is my favorite steel, right behind BG-42. I'd buy more with ATS-34 if they were available.That comports with my memory as well.
I would still like to see some Buck knives produced with ATS-34 as I have several Buck knives with 154-CM and none with ATS-34.
StuntDouble, thanks for posting, looks like you are not the only one with rust. I found some on mine, but it was my own fault though. Recently dyed my handle and that included stripping any oil off of it and putting into a hot dye solution which included salt and leaving for a half hour, guess that was more than the stone washed blade could take! I could probably scrub it off, but it’s a working knife, ain’t worried about it.Used the knife at work again, and had more rust pop up. Thankfully it cleans off pretty easily. It seems to be most prevalent along the spine. I’ve been working on smoothing our the machining marks to see if that makes a difference.
I’m starting to suspect it may be leftover particles from the manufacturing equipment. Mine looked a bit rougher out of the box than some of the others I’ve seen posted, leading me to believe that may be the case.
OK, I caved. I need another knife like a hole in the head, but my 560 rebladed in BG-42 is my favorite large folder. I'm really looking forward to this one. Now all I have to do is sneak it past the wife ... wish me luck.![]()
Better to ask for forgiveness than permission!!!John
You could surprise her with a Smoke Jumper of her own ... or maybe a pair of shoes or a purse ...OK, I caved. I need another knife like a hole in the head, but my 560 rebladed in BG-42 is my favorite large folder. I'm really looking forward to this one. Now all I have to do is sneak it past the wife ... wish me luck.![]()
