- May 18, 2015
Yeah it’s going to be two holes in the foundation. I really can’t get EMT thru the cinder block and rock porch to the other side. I can still daisy chain from one GFI but I agree with you on the Breaker. The weatherproof outlets are subject to be buried under snow. I’m Installing low voltage step and walkway lighting. And the outlets will also be used for Christmas lights.you're either punching 2 holes in the foundation or you're running metal conduit for the second outlet.
You only need one GFI per circuit. (just like a kitchen or bathroom, only the first outlet needs to be GFI)
In fact, running more than one GFI on a given circuit interferes with the way it works and can cause a lot of intermittent issues later.
If it was me, I would use a GFI breaker and run my romex to a 4x4 j-box and split from there to both receptacles.
