ill go ahead and throw this out there now.
the 13 tested belongs to me, is dated 2005 and has the "thin" liners and lock.
all the pivot screws on my emersons, including the 13, are put in place with blue loctite. i do this, obviously, so the pivot will not self-adjust in most instances.
i have no doubt that jim's testing loosened the screw on the 13, loctite notwithstanding. impacts and vibrations will affect screw threads.
but total lock failure from a loose pivot? if i'm reading str's post correctly, that the loose pivot cannot be the only reason for the failure, then i agree. though it is an aggravating factor without a doubt.
i still like eric and spyderco, still like my manix 2, but i am pleased to know what it is capable of doing or not doing. i don't like it any less, and i accept that any design has its limitations.
thx for the post and results eric!
Overstrikes can happen in real world use more so than spine whacks so to me they are more valid than a spine whack or even a spine tap is and Spyderco taps the spine so why the objection to an overstrike? At least you are trying to beef it up to correct for it though, in your defense. That much is good. I disagree with the stance that this test is invalid though as I feel there are times with this type of knife that an overstrike can certainly occur in some uses, like making small kindling or shavings when the knife suddenly goes through faster than you expected and you hit it in an overstrike. Heck I've done that myself on more than one occasion. I think five overstrikes is a valid test that most well made harder use knives should be able to take. Jim didn't wail away on them with full arm swings after all and certainly not with the force one overstrike would have if you smacked it good after putting some ummmph into a full arm slice through a piece of wood to make shavings!
STR
Why doesn't one's fingers block the knife from impact during an "overstrike" assuming the handle is held normally?
Wouldn't it make sense to place the knife against the material being cut while applying the cutting force? And even if you did decide to use your knife with a hacking motion, wouldn't you likely be holding onto the knife in a manner that gave you good control and a full grip on the handle?
So, when you're making shavings, do you swing the knife like it's an axe, hachet, or even chopper? I can see the pressure being applied to the knife and lock in a forceful downward cut, but it wouldn't come from any motion that would likely have the knife missing its intended target resulting in an overstrike(not how I was taught to cut, anyways). Wouldn't it make sense to place the knife against the material being cut while applying the cutting force? And even if you did decide to use your knife with a hacking motion, wouldn't you likely be holding onto the knife in a manner that gave you good control and a full grip on the handle?
Here. Watch this and pay particular attention to like 48 seconds in. Note what happens.STR
Sorry, I'm not convinced. The "overstrike" is a destruction test, not a usage test.
Thanks Eric and Ankerson
Does the over strike refer to a chopping motion, or a hard spine whack?
Thanks Jill and Ankerson. I confess that I myself don't see much value for a knife that can handle that, but I'm sure that there're those who do.
I'm really looking forward to the "improvements" on the Manix 2. Should be nice![]()
