I got 2 Chinese knives today, BEE 04mct and Enlan EM01. Grabbed the 04 first, fit and finish look good, but the axis lock was terrible.
Button ends were not sharp, but let's say "abrupt". Uncomfortable, and the "pull" of the axis lock was way too hard. Also rough, and sticky. Not good.
So, I gathered my tools and did a full disassemble. The dreaded "tri-nut" gave me ZERO problems, just used a small pair of needle nose.
The buttons on the axis lock bar were the hardest, had to use pliers to hold one, while I unscrewed the other.
Once it was all apart I used a dremel to smooth the slots in the liners where the axis bar slides. I also bent the omega springs to make them weaker.
After some more smoothing of the axis bar, I re-assembled. Went back together ok, but some cosmetic damage to the axis lock buttons.
I could clean them up, but I don't think I will. After lubrication It works ok. The axis lock is much better, not like Benchmade, but WAY better than before.
To get it to open easily I needed to loosen the pivot to the point where it has a little play both horizontally and vertically. Won't swing closed without help.
Whew....lot of work, not really worth it IMHO. The EM01 is better, really small though. Too small to flick open, for me anyway.
Build quality is good enough, but opening and closing has a rough feel. Seems to be where the liner lock rubs the blade as it is opening and closing.
I could take it apart, but I don't think I will. Neither one of these was a winner for me, I'll probably give them both away. Decent knives for the money,
but they won't make me give up Spyderco!
