I'm not "attempting to say" anything. I AM saying that I cut knots out of 3/8 inch and 1/2 inch polypropylene, poly-dac, and nylon/poly rope with a Schrade trapper. it stayed sharper longer than a Spyderco Military. I was able to make more cuts with the Schrade with less effort, than with the military. Using the military I was able to make 2 cuts into Polysteel Atlantic brand high strength commercial fishing rope before the knife was dulled. Using the schrade for the same job, on the same type of rope, I was able to make significantly more cuts with ease, than I was able with the military.
I'm not a scientist or a metallurgist. I have a knife that I use to cut rope. After 2 cuts with the military in S30V, it took more pressure and sawing action to cut the rope. Therefore I consider it dull and switched to another knife. Another time I used a Schrade Old Timer trapper to do the same work. I did not count the amount of cuts that I made since I was under the gun and had to get the rope spliced. I also did not think that my credibility would be called into issue by some "knife tester" on an internet forum. The Schrade trapper made many more effortless cuts than the Spyderco Military did. At the time I sharpened all of my knives using a Lansky system with oil stones at the same setting (the 20 degree setting i believe)
I'm not "judging" S30V. I am saying that I prefer a knife steel that I can make more cuts with longer, and expend less effort getting it back to my preferred level of sharpness. In my case, a less "super" steel is better. In my case, S30V did not make the cut. (pun intended)
