America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
Roger, have you done much skinning? Especially larger game? And I doubt if anyone would try to take down a knife around the campfire for cleaning. Most likely done after the hunting trip.
I agree that considering the precise handle/guard/blade fit-up on a Fisk Sendero, there wouldn't be much of an advantage, however I have skinned with outer hunters where dis-assembling for cleaning would have been quite an advantage.
What benefit would that be, Paul? I've heard it suggested that it makes cleaning easier, but that seems counter-intuitive to me. With the fixed handle piece that's good and slimy from use, you have one piece to clean. Breaking that knife down into several parts, cleaning / oiling and re-assembling those parts doesn't strike me as "easier" - and seems to invite more potential problems if you don't get everything cleaned / oiled properly before you put it back together again. And doing so in the field creates the risk of some small but important metal bit getting lost in the process - not good.
I think of two of the most widely successful hunter designs in the custom knife realm - the Loveless Drop Point and the Fisk Sendero. In what functional way would either knife be measurably improved by rendering it as a take-down?
Roger
I'd be curious, too. I suspect the answer is "very, very few".
Roger
How many of them were fixed blades ?...I think I've taken every knife that i have ever owned apart.
Roger, I think my shorthand may have given you a misimpression. I was typing while you were posting your original comments. I, therefore, did not have the benefit of those comments that I share. I was thinking in terms of a bolstered hunter and not a guarded hunter such as the Loveless and Fisk examples you cite above. And the "benefit" I was thinking of was that dirt/contamination could get under a bolster whereas, solder tends to keep a guarded hunter much less prone to dirt/contamination. A take-down hunter with a bolster could be cleaned. I certainly did not mean to imply that this benefit outweighed what you rightly state as "potential problems." Ease of cleaning never came to mind. As you state, "that seems counter-intuitive to me", an opinion I share 100%!
Hope these words clarify.
Paul :foot:
..and how many Customs ?
Doug
Kevin, et al,
Just stepped in the back door to grab a glass of orange juice, and here's an opportunity to waste some working time! What am I working on?-an 11 1/2" all damascus,Bark Elephant Ivory scaled, frame-handled, shell-guard, TAKE-DOWN Bowie for Jerry's. Why, why why...
I've done both working take-downs, and collector ones. The working ones were done somewhat like Karl A's, with solid handles, where the tang was waxed and cast for a perfect fit. Then, with a screw on fineal, I felt that the knife was solid enough to withstand chopping. Advantage over a fully glued up handle...to me, not too much. A working knife glued up with a structural epoxy is easily cleaned, and can be "repaired" to a working level easily.
The engraved "Legacy" Kevin posted, and this one I'm working on are a bit different. They're full take-downs, even to seperating the scales from frame. There's definitely the "cool" factor here. And yes, I've received the late-nite call from a collector saying,"I just took this baby apart all the way, and put it back together. How cool is that?"
There is also the very practical ability to send parts to the engraver, or back to me for work.Both those things have been done with my knives.John Fitch once told me he never made a blued finish knife that wasn't take-down, because it would eventually have to be re-blued. You don't cut with the barrel of the average blued gun. (Except for maybe Bruce's)
Now I would tell anyone looking at a full take-down, separating scale, Ivory handled knife, that it ain't for chopping. A stress analysis would show point loads on the corners of the Ivory scales as the handle loaded and unloaded in compression and tension. Col. Bowie would still be able to stab or slash away on that sand-bar, however.
For me, then, it's the cool factor for fancy knives, with a real advantage to engraving and repair.
Speaking of take-downs, I'd better grab that juice, and go fit the butt-cap and thread the tang for the fineal.
John
1) No.
2) That's merely re-stating your point. HOW is the take-down going to get a more thorough cleaning? Keeping in mind that the interior of non take-down won't need cleaning? In what way is the take down giving you "quite an advantage" in terms of cleaning?
Surely you must compare apples to apples. If either is poorly made, it will be disadvantaged as against the other for that reason alone. If you are assuming a precise fit and finish for both pieces, where does the advantage lie for the take-down?
Roger
Disassembling offers an advantage in cleaning where blood/fats accumulate and dries along the seam lines/joints of the guard and racasso intersection (even if not up inside). And especially where stag and ramhorn (my preferred handle materials for hunters because of it's sure grip when wet) are textured where/if it joints the guard/ferrule. Being able to remove the guard makes these areas much more accessible for cleaning. Wasn't trying to be a smart ass in asking if you have done any skinning, just not sure you realize what a mess the knife is in not only when finished but after the trip and you see all the dried gunk you missed removing while in the field.
Now granted, I'm a little "nuts" in regard to keeping my knives and guns very clean. Even the ones I use.
It's only more work and expertise on the front end.Personally, don't think I would care for a "full take-down" knife as it no doubt adds a measure of complexity across the board.
My take-downs are a pure example of simplicity. I will admit, however, that they are NOT of the extreme frame-handled variey with waaaaaaaay too many parts.
And I'm not sure if or how much structural integrity is compromised.
None. At least not in mine. See Don's post above.
I would like to ask makers if in fact they do charge more for a take-down piece?
Not a penny.
As even my fixed assembly knives are created in exactly the same way, right up to the point of that word that is so difficult to say - epoxy.
Granted it's more work/expertise, however I don't think there's been a case where I have been able to see where a particular take-down knife from a particular maker cost more than his/her similar fixed-assembly knife. I may be wrong.
