This is the one I want. Very nice.![]()
HatiOn Lite. Love this knife! You barely see the blue fibers in the carbon scales. But they are there![]()
The HatiOn Lite puts a smile on my face every time I put it in my pocket. But sometimes it feels a bit too lightweight . (Could a knife be too lightweight?) What would be a good brother for the HatiOn Lite?
This is me. Looked at Recon 1 and they only have green and orange fiber.I’d want one just carbon with no color though.
knoefz , as you felt my earlier RDD disassembly never occurred due to an absence of pics, I made sure to document this morning's opening.
The good Dr's clip had some lateral play in it, shifting up and down slightly over the Mayo hole. Its base sits in a milled out recess at the butt of the lockside slab and is held in place by a single interior PacMan screw.CPP had sent me the original hardware that he had replaced and I measured the extra clip screw to see if it might be shorter, thinking the issue might be caused by bottoming out in the clip. The installed replacement screw was actually .016 mm shorter, so I tightened it down as much as I dared without positive result. I ended up using an old suggestion from @anvil_den for a lightweight thread-locker and painted the clip recess with clear nail polish which seems to have done the trick.
Here's a few pics I took along the way....
...including another hole-y knife that seemed the most appropriate piece to have along as I worked...
...and after I finished.
Does anyone know why Shirogorov stopped using Vanax 37?
If your interested send me your info and I'll mail it out to you. (totally free of course)
Unfortunately M390 was just outselling Vanax. For what it's worth Vanax is a nitrogen version of Elmax and M390 beats it out in edge retention and most other properties besides Vanax's extreme corrosion resistance. The Vanax blades usually had extract cuts as well on the blade spine which I thought were cool.
Thanks for that answer. M390 is a great steel, no doubt. But it is barely superior to Elmax for edge retention: In CATRA tests M390 got 958.6 cuts vs 930.7 cuts for Elmax. And at a point higher Rc, Elmax has better edge retention. In addition, Elmax is considerably tougher than M390.
My impression is that Vanax is a bit better than Elmax for edge wear, but I can't find numbers. Vanax has 3.5 percent Vanadium, vs 3.0 percent for Elmax. And Vanax is tougher than even Elmax, up to 25 percent more according to the maker.
So I thought the super fine and long-wearing edge that Vanax gives, the toughness and the incredible stain resistance would make it a big winner for Shirogorov. I'm sad it wasn't. Fortunately, I have a Vanax 37 111.
