- Jul 4, 2016
Just out of curiosity how diff is it to get ahold of a full custom. Not that i can afford
1st rule of fight club....Just out of curiosity how diff is it to get ahold of a full custom. Not that i can afford
Well played!
Yes, but does the 2nd Rule also apply?
EVEN more so!
I'm hoping to own 1 custom shiro at some point. But seeing the recent auctioned ones going for 11.5k and 13k, that might be a long wait for me.
What is your most favorite(s) Shiros to date? I'm sure you have some outstanding customs in your collection. 👍
So far I've only had my F3 Python apart, and not initially to improve the action, but to work on the lock-stick issues I've noted over the past few pages. I know that the previous owner of my knife had it apart as there are photos of it torn down back in the early pages of the Den. I had no grittiness in the knife at any point, but did feel it was a tad sluggish in closing. I initially found some sort of fairly heavy, darkish lube in it that was more viscous than grease but heavier than any regular oil which I replaced with W10 NanoOil.
More recently, as I worked on and reduced the lock-stick issues, I also polished the bearing chases, blade tang interface, and bearing retainer rings. This time I reassembled with W85 Nano. The action is much freer now and I haven't picked up any grittiness along the way, although she's been carried maybe two-three days since and not subjected to any more dirt than lives in my pocket.
As to my 95T, it's not been taken apart and was purchased brand-new, so it's stock in every way except for a SharpMaker touch-up. That knife has been carried and used quite a bit, both casually and in carpenter-work environments and has picked up no grittiness whatsoever. It closes under its own weight and seems to operate more freely, once broken in, than does 89's in his vid. No flies on your Turtle's action, though, Stoker.
I've often wondered about grease in ball-bearing knives as it seems to me to just gunk them up. I've been very pleased with the performance of NanoOil in all my knives, though I've lately been using Tri-Flow in those knives of mine with Teflon washers.
Since I heard it mentioned a few times now, what is meant by "polishing the bearing race"?
Does that imply using a dremmel with a buffing wheel and some light compound? Or some other method? I know what on the knife is being talked about, just not clear on the method used.
Im not sure if the detend ball is same size as bearing balls but once u know the size i hear its not too diff to replace
You talking diy? That would be awesome, I really don't want to send it across the world for a tiny part. I will if I have to though, obviously.
I believe the bearing size has been confirmed at 1.5mm. However, I don't know if the detent ball is the same. Also, I don't know if the method of retention is easy to reproduce.You talking diy? That would be awesome, I really don't want to send it across the world for a tiny part. I will if I have to though, obviously.
I'm going to add one more Club Hati [emoji6] [emoji106] [emoji106] [emoji106]Actually, too long without pics. Thread needs moar pics.
