alude904
- Jun 4, 2012
Man... i want a 111 so bad because they’re so beautiful but it’s just slightly too big to carry for me.
Yeah that’s what I’m saying. I understand the F35R has thicker slabs but the internal milling is the same. Not complaining though, just wanted to spark some curiosity on their pricing structure. I guess at the end of the day, thicker slabs of ti and some slight outside milling are more costly than ti liners, back spacer and separate cf milling.I just searched F3R again and found a Russian image of one disassembled showing internal milling on the Ti slabs. Regarding my point about the extra work in the inside of the 95s--never mind....
Edit: Also found one of Vlads Blades vids showing the internal milling on the F3R.
You can run your phone battery dead checking every few minutes--like they're gonna send updates every time your knife moves another hundred feet.Hoping the USPS gets their collective poop in a group tomorrow and my new F95T arrives as scheduled.
Why is it that wait time expands directly in opposition to the proximity your knife is to its destination?!
Just beautifulTRfromMT ! Love that blade grind at the spine on the new R series Ts. What's the steel on that? M390 or Vanax37?
You have my permission to sit at your desk and play with your new bear the rest of the day.![]()
Congrats on the new shiro! Looks great.Two very basic observations so far (apart from this being the sweetest knife on the planet!)
1. The tip of the pocket clip is pointy, almost sharp. It seems my middle fingertip naturally finds it when I'm flipping the blade open. Just a small poke each time. Not an issue at all, just seems like an outlier for otherwise exceptionally well thought out machining on this clip.
2. The pivot screw on mine is loose enough that I can turn it with my thumbnail. No big deal at all, just tightened it where I want it with a nickle (an actual silver one, pre 1964, I picked specifically for the job) and when things seem appropriately broken I will get just a touch of lock tight in there to set it.
By the way, this nickle is going to be "modified" to fit the main pivot screw head and the clip and backspacer heads. Should prevent marring the screw heads.
That's all for now....
That is odd. Ive never seen a shiro lock up at 50% with a normal flick. Both my f3r and f95 lock up at about 10% and when i firm grip the f95 it maybe gets to about 40%... maybeAnother couple observations...
3. With a normal flick open, the lock bar insert is about 50% engaged and unlocks smoothly. If I use a firm, full fist-grip the lock gets fully pressed over so the titanium "tab" is touching the blade and the insert is 100% engaged. In this condition the lock is very sticky. Anyone else exlerience this?
4. This dark blue anodizing is beautiful in person and very subtle. Colors around all the little ridges are very cool.
I think he means at 50% of the lockbar, not the tang. 50% of the tang is about where you get pushing in til the lockbar hits the positive overtravel shoulder.That is odd. Ive never seen a shiro lock up at 50% with a normal flick. Both my f3r and f95 lock up at about 10% and when i firm grip the f95 it maybe gets to about 40%... maybe
Yes, (not the conventional reference point, I know), I am talking about 50% and 100% of the lock bar insert being engaged. 50% would be just past the break if the chambered edge, and 100% would be the little tab of titanium lock bar in contact .
