Thanks, Ursa, I briefly had a 111 but never took it apart... or even used it...
Hey, I dont see a stop pin on the 111, is the blade hitting the back spacer when closed? Im not sure i used the right terminology, im just trying to figure out what stops at the fully closed position?
Not my images, but you can see how its working...
Yes, looks like very old model.Good pics of the stop pin, Vlad. That must be an older 111 in S35VN, eh?
I'm not sure there's anything to be lost by carefully trying, @TRfromMT . I think the key would be if the blades are identical, both for locations/sizes of features--pivot and detent holes as well as cut-outs for stop pin and lock ramp--and for thickness. Your knives are from two different series, one older and one R, so that's a consideration. My two 95s--older SRBS T and newer R--have different blade thicknesses (4 mm for the T and the fairly rare 3.5 mm on the R) so I'd not even attempt mine.
All other things being equal, I don't know that one knife being SRBS with the other MRBS would make a difference. Of course, as @CPP has indicated in his post, the blade swap would void the warranty, but, reading the Shiro warranty with Google Translate, it does not seem that dis-assembly voids it. Damaging components thusly does, however, so one would have to be careful not to cause any swapping and re-swapping should one or both knives not operate or center properly after trying. Considering that the knives are hand-tuned and fitted at the Workshop, as has been stated, that could very well be the result.
Funny you ask that because @PharetH alluded to the same issues and had asked me the same question over at the Carothers Performance Knives subforum on this Site. After finding with them most of the afternoon, I've found that the NeOn Lite is a much better free dropper but both of them flip like a rocket (in fact, the HatiOn Lite may even be a little more rocketish!) but when it comes to free dropping, once I got the hang of the NeOn which is small in my hands just like the HatiOn Lite was, the NeOn free drops much more smoothly. I was not aware of such issues to this date and TBT, it doesn't bother me that the HatiOn Lite is more rigid other than the fact that its blade bit me once ever so slightly when dropping. As for the texturing on the CF side of the scale as compared to the Ti, yes its more noticeable when giving it the tactile exam, but as far as the grips go, the noticeable differences are negligible.
photo_2018-10-06_21-06-47 (2)
photo_2018-10-06_21-06-48 (2)Great looking Shiro! That CF inlay looks like it might be textured, is it?
Nice, I wish they had done that on the micarta inlays ones to give it a little more grip.Yes, it is. Closest I can describe it... It looks like the top of a block of cheese after grating. "Cheese grater texture"
