Wow, I was physically giddy seeing how flat your freehand edge was.
Something that I don't understand, is how you sharpen the curve or belly of the knife. You say you move the handle vertically, but do you also swivel the blade so the edge is always perpendicular to the direction of sharpening? And how do you keep a steady angle when you change direction form forwards to backwards? I always do a little wobble that throws my flat bevel right off
Slightly off topic, but what is your opinion on convex knives
Thanks.
Knifenut, I'm a new member entering into a new and amazing world. The technical terms lose me at times but the process is absolutely fascinatng. Have really learned some valuable technique reading this thread so can improve the edges that I already have. You have a gift and kudos to people like you who are willing to share with others (and convince people like me to leave a virgin blade to the professionals so I can at least try and follow in your 'tracks'). Looking at buying a quality knife once I can settle on one and would like you to put that first edge on it. Can you ship to Canada? This thread should be a sticky!
It will treetop, whittle, and draw blood at the slightest touchbut sometimes that's just not good enough
I find myself not wanting to use the knife for anything more than opening envelopes, for fear of dulling it, and having to do it over again. Yeah, I know most edge wear can be taken care of with a few swipes on a strop or finest stone if caught early enough
I keep a DMT aligner clamp handy for use with my bench stones, its not used often but is nice to have on my off days.
If you have diamond bench stones then you should really consider the aligner clamp. Its a lot cheaper and with the EEF stone it will produce edges more than sharp enough, if the appearance and appeal of the mirror finish is what you want though the EP or WE would be better choices.
I had time to work on my new BM Torrent this weekend. I did spend a couple of focused patient hours on it with the Dia-sharp stones and magnifiying glass to look at the edge. I found that I could get the blade to just barely cut paper. And at times, if I continued to try to improve it, I actually ended up going backwards. I would make it "unsharp". I believe, from what I can tell looking through the mg, that it's probably because I am sharpening at a different angle. It's really, really hard to keep a 20* angle by free hand with out tons of practice. Still I dont want to really on something like an aligner yet. At the same time, I realize that I will never really spend the hundreds of hours programming my muscle memory at holding a 20* angle. Well...since I know I can't hold the angle to well on the stone lying flat, I'm sure I can probably hold a horizontal much better. So I'm gonna try to to prop up the stone at a 20* angle instead and go from there.
Any tips would be appreciated.- Thanks.
You should really post a video of your sharpening technique!Yes, you can make a knife cut directionally by the way you sharpen it.
Diamonds are excellent for all around sharpening and if you sharpen a lot of very hard steels but don't give up on the water stones yet
There is a "flow" when sharpening and a mental state you must be in to "feel" the edge when you sharpen. The method of pressure points/angle control explained on page 3 is most important in the technique, beyond that my body movements are whatever feels right for the moment. One thing is to keep your wrist locked and move your shoulder and elbow joints. Or you can sway your body while having your arm joints locked.
I like to have the stone at a 45 degree angle in front of me as it feels best. I know this may sound odd but try sharpening with your eyes closed, shutting down one sense heightens the others![]()
OUC, you are not alone! I have been trying to sharpen a knife freehand for the last few months, don't have much time on a daily basis, but try to practice here and there. I still don't feel whether I am on the edge or not, end up with multiple bevels, I grind and grind and the knife gets rather duller.I had time to work on my new BM Torrent this weekend. I did spend a couple of focused patient hours on it with the Dia-sharp stones and magnifiying glass to look at the edge. I found that I could get the blade to just barely cut paper. And at times, if I continued to try to improve it, I actually ended up going backwards. I would make it "unsharp". I believe, from what I can tell looking through the mg, that it's probably because I am sharpening at a different angle. It's really, really hard to keep a 20* angle by free hand with out tons of practice. Still I dont want to really on something like an aligner yet. At the same time, I realize that I will never really spend the hundreds of hours programming my muscle memory at holding a 20* angle. Well...since I know I can't hold the angle to well on the stone lying flat, I'm sure I can probably hold a horizontal much better. So I'm gonna try to to prop up the stone at a 20* angle instead and go from there.
