Gaston,
Really interesting reading, and great pics.
I'm very surprised about the final edge angles you've chosen. I would think they would be very delicate for a "chopping" blade. When you say "20 degrees inclusive" you're saying 10 degrees per side, right? Are these steels up for that? I would think all of these blades are made of fairly ordinary steels like 440C, and the Randall's O1 is only hardened to 55 or so. I'm surprised you'd want to go smaller than a Mora at less hardness on a big, heavy blade.
BTW, I didn't see why Randall didn't fix their screwed up knife. What happened with that?
Gaston,
How is the sharpening rod attached to the CRK sheath? Besides the cord, I see two clips and something on top. I like it. It looks very clean. If it isn't too much trouble, a better photo of the attachment would be helpful. Thanks.
Thanks for your comments. I'm always surprised by the incredibly wide variation in what people consider to be a useful edge - especially with the very wide variations in hardness and wear resistance just in the samples you have.10° per side can easily take chopping on soft wood. According to those doing testing using chisels, below 40° the edge's very extremity suffers much more micro-chips than at 40°, but this assumes consistent sharpening angle all the way to the edge extremity: Highly theoretical with free-hand sharpening like I do... And even if they do micro-chip at 10° per side, I still prefer micro-chipping and having a thin edge that can still saw with, rather than 20° per side which is to me completely unsatisfactory, no matter what anyone says... Even 30° inclusive I consider barely safe to use...
The reason Randall did not fix the Model 18 is because I knew they couldn't: The guard was welded askew, and they would have to replace the whole knife, and that is no good to me (neither would be re-welding the guard/handle: Good grief!): The Model 18 is so loosely made that the 18 model # is basically utterly meaningless -from my point of view- as to the actual shape of knife you are going to get (in particular blade width and point geometry): If they can vary the same model from 11 to 19 teeth (and you can see how vastly different are the two Randalls I show, despite choosing the blades to be as close as possible...), then I have no idea what the replacement knife I am going to get will look like: I choose that specific blade shape out of around 8-10 Model 18s sold by the same dealer on Ebay. His prices are a little higher, but you get a variety of the same model to choose from, with their varied blade shapes, and that is worth it to me... Losing the shape of the guard is not a big deal in comparison. In any case, the 0-1 steel stains worse than most steels I have seen, and I would have avoided that steel if the shape of the blade had not been so close to what I want. None of the stainless 18s he had I liked... I am quite happy it is coated now, and for the guard... Well it looks kind of meaner that way...
Gaston
I've looked at my knife, blocking out the guard from varied viewpoints, and you are right: Removing both lugs, leaving only the top hole and grounding off the bottom hole actually equalizes the top and bottom of the guard, and the width and proportions of the guard still look fine: It actualy looks like a factory-intended design, except for the oddity of there being just one hole...
The hard part left would be rounding all the edges evenly, on steel, and equalizing the finish all over the guard...
Gaston
Lol I sent it to him. Its #36 bank line you can pick up at many outdoor stores in the fishing dept. Even walmart sometimes. Also known as trout line.Where did you find the green rope for the handle?
And an ESEE Laser Strike
It's tough to tell that the ESEE is a hollow handle, but it is. Inside a hollow there is a fire steel and two tinder bundles.
Full testing will commence soon.![]()
