Those are making the rounds up here at $150 a pop. Not a bad price for us Canadians.
What do you think of it?
i put the lowers in the safe and haven't had a chance to do anything with them yet.
I am not about to let this thread die!
Gents, if you have MOE Handguards you will want to check out this giveaway on my blog for Mount-N-Slot sling mounts: http://jerkingthetrigger.wordpress.com/2010/08/19/mount-n-slot-giveaway/
Good luck!
got the mount yesterday! can't wait to get a midlength handguard to put it on.
What's everyone's thoughts on single point vs two point slings. I'm having a bit of a real estate issue on my handguard. Once I have my illumination kit on my carbine length MOE handguard, if I put what appears to be the excellent Mount-N-Slot sling swivel on the same side, I ain't got no room for my hand. I could slap a rail and an AFG (very comfortable, BTW) below the handguard to give me a little more room for my hand, but that's a little more complicated than I was hoping for, or I could just go with a single point sling...
I have got the ASAP on two of my AR's and LOVE them!!! They are a PITH to install but well worth it IMO.
Good advice Matt. Do you have a personal preference between the VTAC and VCAS? I'm trying to decide which one to get. I think what I'm going to do is this:
-Move my light from the 10ish o clock position (non ejection port side) to the opposite side and drop it using a Vltor offset mount (have you heard any reviews on those by the way?) so i can go under the handguard with my left thumb to activate the light.
-Use a Mount-n-slot QD slot mounted near the front of the handguard at the 10 o clock position, and run the rear of the sling through the slot on the MOE stock.
what do you think?
Or, what I would do...
- Mount the light as far forward as possible (should be done anyway) and the sling mount as far back as possible (should be done anyway). Before you worry about having a problem get everything mounted and shoot it. It may be a non-issue. You might be surprised how well everything works together.
