snip>
He said that he primarily uses RRA for his builds because he's found their quality to be the most consistant but that companies like CMMG and Del-ton make a decent product and if you have problems they'll stand behind it.
In regards to this, there have been numerous issues with the mag wells not being to spec. There still are much better lowers to choose for builds, and it really surprises me that he still made that recommendation. DPMS and RRA lowers are frequently two of the last choices for builds.
He said that I'm on a good path with the Del-ton lower, he said he likes Del-ton for their lowers more than their uppers, and he said that CMMG is doing a good job on their staking, feed ramps and barrels. He said that if I were to have a problem, they would take care of me.
Now keep in mind, this conversation was started on the premise that I was doing a budget build that I would be continuing to improve over time.
This makes more sense. CMMG and Del-ton are frequently considered by people just building a budget build for casual use. If you are considering buying quality from the start, look for for some other companies to compare as well.
As for the rifle length, He was reccomending a midlength gas system with a low pro gas block and a rufle length handguard. Me being a rifle shooter, the longer handguards will make it more comfortable for me and a mid-length is going to be more reliable.
BINGO! This is much much better than the Dissapator systems that have been marketed in the past, and a wholly different animal. The rifle length handguard he's talking about though will likely be a rail system unless you're going the Bushmaster-method of installing a gas block and then installing a front sight block near the muzzle. The lo-pro mid length setup from BCM with the DD Omega rifle length rail will be the setup I purchase next for the duties that don't involve going inside something. Sounds like you're looking for something along those lines as well possibly?
Another cool option is that I made a friend at Daniel Defense and he gave me his card and told me to call him about scratch and dent uppers that they have laying around the factory.:thumbup:
This is one of the advantages of making contacts at SHOT I'm assuming...
My AR is a tool. It's not meant to look pretty, and will get scratches anyways.
Also was given a video and card from a fellow from the Noveske shooting team and he said that he could get me a line on one of their lightly used barrels.
