G2,The Lynch clip has a reduced area at the top which helps keep the lanyard in place so when clipped in your pocket the lanyard falls down and covers the clip
G2
What's going on here?Put to use.
I thought it looked like a waxed thread but wasn't sure. Thank you for the info!Thanks, I get it from here
Maine Thread company
one of the key points in using a whip knot is once you wrapped it up close to the knife, you need to pull one side of the loop that will cinch/tighten up the start of the wrapping, otherwise it will be a loose mess. Then after it's pulled tight, careful not to pull the tail sticking out as you'll need that to complete the knot, you insert the one end through the loop and then pull it down tight and just part way under the wrap, snip it off close, and then 'carefully' pull the small tail end so it's fully under the wrap and then snip off the other end close as you can. I use small scissors on my SAK Executive folder.
G2
Me understanding that ^ is like me telling you how to do an appendectomy.Thanks, I get it from here
G2
Lol well, THAT wasn't meant as a tutorial, but further back in this thread you would have found my link to my actual Tutorial that explains things a little better, such as the whipping knot, it doesn't cover the Wide diamond, that I may do sometime but it's a complicated thing to show
My tutorial on tying lanyards
G2
Gary, what size do you find most useful?Thanks, I get it from here
G2
You do some really nice work with stag.Here's some Opinel Knives that I customized and added lanyards too...
Now that looks just pretty fancy. I like it.
