- Dec 4, 2010
I don't believe there is. The one thing I really like about the knife is that all the screws are the same size
I've never held a ZT before...what does the other side of the blade look like at the pivot? Is it recessed as well or are the bearings offset or something?
No it's flat - the two recessed areas are where the two blue KVT bearings fit.
I see...so the recessed area on the Ti scale matches the recess on the blade? Interesting.
I don't think skeletonizing the liner would make a significant difference in strength, but I wonder if it would make enough difference in weight to make it worth the effort. Even if it saves half an ounce, is that a meaningful enough difference to make it worthwhile? Is 1/2oz less weight something you can even feel clipped in your pocket? I doubt it.
Are the recessed areas of the Ti scales carbidized? Does it make sense hat the steel bearings would wear into the scales eventually causing blade play
Is there a need for both a hinderer LBS and an over-travel tab on the steel lockbar insert?![]()
There is no way. I wouldn't be shocked if the liner weighed under an ounce. That means you would need to remove 50%+ of the material to get a half ounce of savings.
Half an ounce is 10% of the weight roughly. I doubt considering the blade and the thickness of the to, that carving out the liner will get you 10% of the total weight.
So not only is half an ounce not enough to feel in the pocket, the chances of you saving that much are slim to none.
I have an idea. Let's petition ZT to make a 3.0" version of the 0562CF that weighs around 3.5 ounces. That would get the job done, right?![]()
I hope they make a 3.1 inch blade that weighs 4.1 ounces.
