G
Gaston444
S30V and S35VN tend to develop lingering burrs in my experience. Your description indicates that you have a wire edge or foil burr, rather than clean apex.
Once they are removed, I think the edge would be more stable even at 15 DPS.
In your dreams that any of this CPM stuff will not grab your nail on one side if you
breathe on it at 20 DPS. I have dozens of pictures of various knives, some customs into the 1.5 K range, where you can see the nail material grabbed in different edge areas from
individual hits on Maple...
I never saw a CPM steel micro-folded edge completely roll over 180 degrees (as I did with really bad 440: Most other poor 440 just chipped long before getting to that point).
CPMs just seemed to grab more and more nail material, as if the rolled portion became taller and taller, working its way up the edge, but the apex itself would not bend beyond a certain point: The rolled apex seemed strong enough to not bend further, instead "taking with it" thicker and thicker steel below itself: This, however, does mean the apex sideway misalignment was still getting worse, but doing so in a way that made apex chipping less likely.
It is quite possible the apex on CPM steels remains sharper (and more chip resistant) than on other steels, even when rolled, and that despite the rolling it still resists chipping by "spreading" the micro-bending up the edge (until it is definitely not "micro")...
I don't find this acceptable because of the height loss issue: To restore the edge you will have to remove more height than on a steel that stayed "straight": This eats faster into the "reserve" of the main edge bevel, in turn forcing a more frequent re-profile, this eating faster into the "reserve" of the overall geometry.
There is also the issue of the blade "skipping" when chopping into wood, because on at least one side of the "V" cut your edge will be rolled "away" from the angled wood, making it bounce sideway dangerously. I did notice this, and this is quite unacceptable for a big "Survival Knife".
That being said, for lighter tasks, it could be that the micro-rolling is largely an academic issue, especially on folders, and that these edges keep on slicing forever in their micro-rolled condition... The dividing factor is perhaps the use of chopping motions: I find small chopping impacts useful even on very small tasks (contrary to what is usually said about this, this means occasionally big knives do small tasks better), and that would tend to spread the rolling upwards on the edge compared to slicing.
Gaston
