Try to think about this logically...
I attack all the CPM steels, that I know of first hand, as not good for knife use: These four that I know of extended my skepticism to the entire process... Is that hard to understand?
I noticed all four, that I know of, bend their apex with the same astonishing ease while chopping, even at thick angles, in a way that is immediate and typical, and unlike all other steels I ever tried (cheaper steels do this at thinner angles, but not at angles as high as the 20 dps CPMs will do: This makes CPMs indeed the bottom of the barrel as far as micro-folding goes). What difference does it make if some CPMs were formulated for knife use?
Saying some CPMs were "formulated" for knife use amounts to a weird, completely non-pertinent authority argument...
Ok, maybe it means that, among the morass that are CPM steels for knives, those "formulated for knives" are a little more knife-like in performance... That way you can say "the experts" did do their job. But it has nothing to do with what I say, or the underlying apex stability problem, which is blindingly obvious if you do ten chops at 20 dps into any kind of dead wood, even if just as a micro-bevel. All you have to do is stop slicing paper to test your edge, and instead rub your nail on the apex, away from the cutting edge. It will instantly jump out at you: Not complicated, and I even learned the nail trick on Bladesforums...
Gaston
