The "blade too long" is what I've found in the dozens of 110s I've put lanyard loops in. All of the grinding and finishing does change the blade length, and the belly slightly. If they undergrind the blade, it hits the spacer more readily, if they over grind it, it takes more force to get it there. My lanyard loop / spring holders are all identical, but I have to "dry fit" it in the knife before permanently pinning things together. Some I have to grind more clearance from the spring holder, some I don't. If you're careful, you could use a die grinder with an abrasive disk and slowly grind some clearance room from the spring holder while the knife is assembled. As for a dab of hot-glue, a piece of rubber, or plastic; eventually the blade is going to cut through and get to the steel again. You can't stop the blade's travel, all you can do is give it more room or give it a bumper.
