But virtually any carbon steel is going to be tougher than most stainless steels (AEB-L being the most obvious exception).
1095 is not tougher than any stainless, but is likely tougher than the uber steels popular today.
Great info, thanks all !
As far as the Crovan being sooo much better then 1095, anyone ever test this?
I've used quite a few steels. 1095, and a handful of other 10XX steels. I've used tool steel, spring steel, ball bearing steel, and some proprietary steels like INFI.
I'd avoid taking sweeping statements as gospel:
Just want to say this is a very interesting thread filled with lots of good info indid not know. Now I have a question and forgive my ignorance on metallurgy. Ive read before that the modern supersteels do not make good fixed blades or choppers or swords due to them being powdered steels, from what i remember it was said the grain is a lot smaller so you get better edge retention and can hone very fine edges they cant take a good hit and is brittle due the fine grain which is why you see them mainly in folders. Whereas your carbon steels like your 10xx's and such have longer grain and link together better i would guess.
I think of it like ply wood vs. Particle board. Particle board can be shaped more finely and smooth but is weak in lateral strength comapred to ply wood that isnt as pretty or able to be worked finely is is stronger laterally.
Also what steel types allow differential hardening and hamons and how does that effect the equation of the topic. As far as i know only carbon steels can take a hamon? Sorry if this doesn't make any since, its late and I'm tired from work.
Not my graph =P Some knife MFG ( I think)
Found this online.ONLY graph like this I could find with 1095 on it.
yea, these guys know some knife stuff =P
That Bark River Senegal looks NICE ! Shame its only A2 and Not 3v.Wonder why they only used A2
I had bad luck in the past with chipping, I just cant get anything that chips again.
I was hoping the "most" part prevented it from being too sweeping. I wish someone could find a temper/impact strength chart for the 10xx steels. I keep looking. But generally, it certainly looks like this:
This is a good general primer about steel properties, alloying ingredients, toughness, wear resistance, etc.
https://www.crucible.com/eselector/general/generalpart1.html
.Now I have a question and forgive my ignorance on metallurgy. Ive read before that the modern supersteels do not make good fixed blades or choppers or swords due to them being powdered steels, from what i remember it was said the grain is a lot smaller so you get better edge retention and can hone very fine edges they cant take a good hit and is brittle due the fine grain which is why you see them mainly in folders. Whereas your carbon steels like your 10xx's and such have longer grain and link together better i would guess.
Differential hardening is just when you have one piece of steel that is part hardened and part not. Generally, un-hardened steel has few properties that an engineer would desire. It was a good way for people with no thermometers, torches or anything else but a hot fire to get steel to behave in multiple ways at the same time. Differential tempering is a more modern, and sometimes very controlled, way to heat treat all the steel for its best properties, then make those properties vary across the steel. 50 Hrc and tough in one spot, 62 and more brittle in another. The idea is to put a brittle edge on an otherwise "tough" ductile blade. It is generally unnecessary and sometimes makes a lower quality product.
Hamons are the visual manifestation of where the two steel states come together. Some alloys show it better than another. It is just aesthetic.
When people state the term toughness, expectations are different among knife fans. My personal measure of toughness is how well a properly heat treated steel holds up against some hard abuse that most people never really expose their knives to. Throwing a knife at a concrete wall, chopping into cinder blocks, cutting into other steel objects (Busse), extreme flexing of a knife locked in a vice, beating on the knife blade such as batoning, or chopping into hard wood trees. I normally would not attempt anything extreme with my knives, but it sure is comforting to know that a knife can stand up to serious abuse. An appropriate heat treat also contributes to toughness. 1055 to 1095 steel when heat treated to an optimum hardness can stand up to serious abuse and seem virtually indestructible. However, better edge retention usually means a higher hardness which can mean less tough sometimes. 1095 is a good balance of high enough carbon content for good edge retention and toughness. It is hard to find anything stainless that will outperform the toughness of 1095 for the same price point. The recent taiwan based production of cold steel 3V steel knives challenges this price point concept in my mind, but I still do not quite believe that just because a knife is made of 3V and no assurance of an outstanding heat treat that it will stand up to abuse as well as a 1095 steel knife with a well known heat treat reputation.
