BluntCut MetalWorks
- Apr 28, 2012
When comparing hardened steels performance in a wide spectrum of edge applications, perhaps best to focus at steel optimal ht microstructure rather than slog through mountain of data on instances and group of instances per steel. Also keep other variables (profile, geometry, hrc, etc..) the same.
Optimally hardened 1095 has a slight advantage over good ht 3V in thinnest edge stability, trail on wear & corrosion resistant. Here is an excerp of my yt response to Cliff Stamp about W2 vs 4V.
ref: https://youtu.be/vkWtqkW3UHY
My current attempt to produce higher homogeneity(by reducing carbide size) microstructure for D2 & 3V. Even though hted 3V only has around 2.8% carbide volume but like many PM steels - carbide dia in 2-4um is cube root less population than steels with nominal carbide dia in sub 500nm range.
http://www.bladeforums.com/forums/s...chopping-impact-tests?p=15943800#post15943800
Why D2? because it is well known for having low toughness. So, I have to show a few instances of D2 high edge stability at 63-64rc.
4V and other high alloyed steels are higher heterogeneity microstructure as a whole than W2. Heterogeneity is a self feeding behavior when hardening, which spiral toward higher heterogeneity (RA; carbide+precip_carbide coarsending; freed ferrite). heterogeneity may register higher reading in hrc because intrinsic high dislocation, especially in high irregularities in grain & carbide boundaries/interfaces.
These high alloyed steels are inherently brittle even in lower hardness. Once plastic flow caused particle pileup (it's a jammed situation because of irregular shape particles interlocked each other), cracking force will propagate.
W2/52100/etc has smaller particles (grain, carbide & crystal cells), thus pileup volume is larger. Implied wider volume/band of propagation, hence bigger impact load. The 67.25rc W2 blade had big chip (and the 65rc blade too) both received poor strikes/batons with high rebounced, most important aspect I look for is the radius of damage (from point of impact). Global/cascade is bad - as in case of 4V.
In term material fracturing efficency, thinnest apex radius + cutting wedge shape with highest stability and retention win. Fracturing approach (cutting/chopping) style & material hardness/abrasive affect retention outcome, so there are certain amount of tailoring on microstructure (heterogeneity or Homogeneity) depend on applications. Master ht of low alloyed steels is a necessity foundation. Sometime, I look at 3V/M4/etc as microwave readied dinner packages
