- Nov 12, 2009
I received my copy - a black coated version with plain edge.
It is a big knife and heavy - but I did not have too much problem with it in my pocket - the clip works fine.
The knife arrived sharp enough - not a razor but it will push cut, and the edge is very even and nicely done.
The odd upward-sweep of the tip makes it interesting to try and pierce-cut things - so far that is about all I have cut with it.
I notice that the lockbar is a bit thin, and there is a fairly significant gap between the blade and the liners, which leads me to believe that the lockbar will eventually wear and work it's way over to eventually "fall off" the back side of the blade tang.
I have seen this with other cheaper knives - like S&W cheapies you get at O'Reillys etc.
I can't say that this knife will do that for certain, but I am guessing it would.
The lockup is tight, but the lockbar is very thin, so it is engaging the tang well past the lockbar side of the blade.
No up or down or side to side play. Finishes are all nicely done.
Its a $30 knife and of the quality that I expect at this price point. When I get better I am pleasantly surprised. This knife is not of the quality of a $30 Kershaw for instance. It is a unique design that I think you either love it or you don't.
Pictures will follow - I'll do some cutting and see if I think the lockbar is going to travel into the "cheap knife pivot abyss" as I suspect.
best
mqqn
best
mqqn
