RayseM
- Feb 18, 2010
Can't go wrong there
Ray
Sharpness is important on a dagger? It's meant for stabbing, I don't care who is supposedly "qualified to explain its basic functionality". Sure, sharpness might be icing on the cake, but I doubt any legitimate soldier who has actually taken a life with a bayonet was worried about sharpness.
Go ask any prison guard about a shank made from a toothbrush, they are going to tell you it was deadly because it's pointy, not sharp. Even a piece of rebar can be lethal, which is why OSHA requires us to put rebar safety caps on exposed bars.
Ray
Yes, they would be able to tell the difference, because with the shank they will have to be stabbed fifty times and will die an hour later, while with a sharp dagger you stab once and make it come out sideways, for more damage in one stab than in fifty...
The recipient will know the difference, trust me.
Gaston
.....very simple question here, as you state this with some authority, how many stabbings have you been present for or in the immediate aftermath to state this ? What is it that you think makes you an authority on the subject ? As frankly others have a significant personal (repeated) experience of the matter at hand.Yes, they would be able to tell the difference, because with the shank they will have to be stabbed fifty times and will die an hour later
Well ..., actually you can.
They are quite fragile, as compared to some more modern dagger renditions.
Depends on your use of course.
If its for admiring the WWII history of these and the slinking about in the alleys of Shanghai brandishing small stubby daggers, from which the FS sprang - then go ahead and buy one.
If its for a practical hard use blade ... then not so much.
Im a fan but sturdy, the FS is not.
I agree with this. I had one about 20 years ago. I broke it. However, like all knives, if used within their parameters, it should hold up just fine. I used to worry about the stubby epoxied tang of the Gerber MKii holding up. Generally the blade will snap before the tang manages to loosen from the handle. Even so, its a killing knife. I'm not going to chop, pry, or try and force it to build me a shelter.
If you were to hand me a FS knife and toss me into a dirty, bloody fight for my life I think it would more than hold up to piecing caradids, puncturing guts, and severing tendons of the wrist. You could probably carve your way through 50 men before you managed to bend it
It's an absolutely terrible knife for survival. It also wouldn't be my choice to square off in a sabre style bowie fight where you do your level best NOT to get cut. However, if I were to be mugged from behind via a sneaky grapple, there aren't many blades I would choose ahead of the FS to jam into any soft bits I can reach. They are ridiculously deadly in the application they were designed around.
Buy once again, you are correct. Certainly not as robust as most other daggers, including the MKII.
I've been lusting after this knife for about a year now. Haven't pulled the trigger on a purchase ... yet.Spartan George V14
As for long slender blade - and very budget friendly - take a look at the Swiss M57 bayos on the surplus market. Blade is app ten inches long.
I bought 3-4 of these. One I left original, on one I cut down the guard and the last one had the guard cut and the blade cut down. Just for the heck of it. I dont carry them.
The beauty is, that you decide the configuration and that the bayos are cheap as chips ... or at least, they were, when I bought the bundle for not a lot of dough.
