MKII stubby tang; I owned several of these prior to stumbling over an article, which showed the tang.
I was flabbergasted!!
As you mention, its a tiny little tang barely stuck in the handle.
The epoxy they use is top notch though.
I havent wailed on any of my Gerber MKIIs but others have beaten the snot out of them - not least in Vietnam.
Ive seen evidence of blades broken and guard 'horns' snapped but not one single instance of tang failure.
Amazing.
it is not amazing: The shorter the stick tang, the less leverage there is for vibrations or force to break it...
Even cheapo United Cutlery Rambos use a similar epoxy, and I've never seen a broken or separated example... Epoxied hollow handles knives are more vulnerable than the Mark II however, because of the large
separate guard construction:
If the tube or tang is smooth inside, banging the guard while chopping can cause the guard to act as a "lever" to overcome the adhesion of the epoxy: This would be totally prevented if
both the tang and the tube handle had a slot or hole for the epoxy to "lock" on...
I've found Colin Cox custom hollow handles are usually devoid of these "locking surfaces", so the guard can easily leverage the tube handle apart: By breaking the tube adhesion on one specimen I had, the tang adhesion on another. I fixed the tube failure by removing all the epoxy (a hard task) and roughening the inside of the tube with a power tool, then pouring new epoxy (the tang itself already had a large "locking" hole)...
If Gerber uses any kind of stepped/rough surface inside to provide a locking surface to the epoxy, it literally cannot fail. Even if they don't, no separate guard piece and no real chopping impact means the epoxy will never lose adhesion. What is great about epoxy (the one usually recommended now is G-Flex) is that it is both very hard yet impervious to fracture, so it both "locks", "sticks", and fills a space, with no tolerance or cracking issues.
The only downside is it "sweats" oil when heating the knife to prepare it for a Cerakoat: By lowering slightly the preparation temperature, it does melt slowly enough to "sweat" over the sprayed paint, not under it, if sprayed quickly...
Many Randalls, including the model 14, also depend on this type of Epoxy to secure the micarta handles, often with only the lanyard tube to offer any "locking" (on the 14, only the epoxy adhesion prevents the micarta handle from rotating downward around the tube). They have no slots or roughened surface: It all depends entirely on the epoxy adhesion alone... The Clinton daggers don't even have a lanyard tube, so it is 100% adhesion (on a short tang) for those. Randall has done this for decades, and they are not worried.
Gaston
