So I read this whole thread, and there were a few comments I wanted to make, even though I didn't chime in time for some of it (and note, I am not a high speed low drag operator, or ever been in a knife fight, or plan on it)
From a medical perspective, a stab is a much harder to treat than a laceration. From my three years working in a level one trauma center's ER, and 4 years before that as a full time EMT, I have seen a fair amount of knife inflicted wounds as well as other cuts and stab wounds. I will give two stories to illustrate this:
1) Thanksgiving day, a couple years back, we had this guy who got drunk and fought with his cousin, who slashed at him once at the side of his head, and opened up an artery right near the temple. The blood was literally making airtime when he came in, and the paramedics were trying to hold pressure as hard as they could, but he was ambulatory, fully conscious and awake, I don't know how much blood he actually lost, but I would peg it at about 600 cc's or so. AKA, a good amount of blood, probably 10% of his body volume. Two staples and 30 seconds later, bleeding was controlled, and he was actually DISCHARGED and walked out 3 hrs later
2) We had this sheriffs deputy who was cheating on his wife, she found out, and stabbed him twice in the upper chest region with a steak knife. He came in, intubated (he had diminished breathing function, because the hole in his lung negated the vaccuum needed to breathe, AKA hemothorax) and despite going straight to the OR, he died a couple hours later.
now to the OP:
There is two real advantages, as I understand it, to the tanto blade shape. First is the fact that is that it introduces the entire width of the blade (in a properly designed tanto) within the first inch of the blade, which is how they do all those car door demos. It takes advantage of the full power of your swing to punch through a thin but resilient material, and then you can easily glide the rest of it through. In a tapered blade, you would experience increased resistance, as you move deeper. The second advantage is that keeping the tip in line with the spine, you are able to provide more material and make it stronger. This of course, comes at the cost of loosing a belly, and having an awkwardly placed tip, which decreases precision of cutting, which is a big part of utilitarian usage. Whether or not you decide this is right for you, is your decision. Also, this is assuming a properly designed tanto that maximizes these features, like this one:
Beware of tantos that drop their tips significantly, like this one:
Because you will find yourself not only with a delicately thin tip, but also with a blade shape not suited for utilitarian use.
Personally, I like the fact that the tip is strong, and the blade introduces it's full width early on, but I did not like the lack of the belly.. so my perfect blade?
the dao shape:
on this picture you can actually see that the tip is in line with where the spine starts, almost like an optical illusion, it doesn't look like it should:
and here you can see the thickness of the tip:
Btw edwood, I love that kydex harness for the hawk!
