- Oct 3, 2002
Thanks, Butch.
I have 4 going out today and will send yours out tomorrow.
I am not currently going for those funny stains on my blades like Don does...lol. What I do is spheroidize anneal for 2 hours at 1250 (just used foil for the first time and it works much better than PBS which tends to flake when left in the oven for that long) and cool like any annealing job. Then I put it in the oven and bring it up to 1475, let it soak for at least 5 minutes and then stick it in the Parks #50 for a full quench of everything except the tang. I have found that if you gently agitate the blade for about 10 seconds or maybe a bit less, it comes out still above the magic 400 degree number so you can straighten out any little warps to the tip. I do it by hand on the anvil using tongs holding the tang and the welding/kiln gloves that came with the Paragon. I temper in the Paragon for 2 hours at 475 once the oven gets up to temp. I have no idea what the hardness is...lol.Butch, you may modify this to your needs but here's what I do.
After normalizing 3 times, I soak for a few minutes at 1450f in my forge (if elec. oven is used, soak for 10 to 15 minutes), then quench in Park's 50.
I temper at 450f for 1 hour twice, for a Rc hardness of 61 to 62.
This should get you started.
Thanks,
Don
You can ignore everything else that anyone as said as long as you buy Park#50. Even a semi-fast 11 second oil like Tough Quench will likely not fully harden the thicker parts of a big W2 blade.seeing how im used to tempering at 400 or 425 that works for me
the kitchen knives and razors shouldn't have much problem at 62 (least for the guys that will be buying the kitchen knives) i ll have to test the razor RC to see what works best but the kitchen stuff should be fine (running cpm154 at 62 no problems ) those guys like there knives thin and hard as hell and are not worried about a little micro chipping
Hi Phyl, yes I'm still peddling and will have this 2" W2 available for a good while. I have shipped a bunch (at least a ton) to you part of the world. So the Postal service knows the rout.Are you still peddling this stuff? How about in July? I believe I've tapped out my metal budget until then.
