Chris "Anagarika";12861748 said:I was thinking why not slicing sandpaper, all new from same brand, same grit (preferably high sothe impact is more uniform)? This way it will be totally measurable without impact blunting.
Sand is cheaper though. However, the abraded steel will be left in the sandbox, contributing to next knife test (more like polluting)???
Perhaps 12 fresh box for each?
With this test, you can make edge geometry the same for all, another factor eliminated.
Seems that this test is more about proof in method of cutting more than what is being cut. Obviously some things will wreck an edge, but the rope and fronds are close to what many knife users see (mostly cutting food or opening packages), and almost all of the wear seems to have come from hitting the cutting board.
Chris "Anagarika";12865647 said:Some has nice rings going through the sand. Also I'd say this test is quite focus, only measuring the abrading factor. Perhaps we can use this as standard?
You seems also to have mastered 52100 HT (mostly Cr carbides?) as it comes near the champs with lots of V carbides.
Hi bluntcut, I have to keep complementing you for doing this! My favorite steel 52100 seems to perform quite well. I just noticed however that there is no 3V steel in the test? What is your expectation how it would perform?
Chris "Anagarika";12868602 said:Tough question.
Slicing? Push cutting? Balance between two?
What being cut? Hanging or on cutting board?
If you're thinking EDU (borrowing Martin's term) then Ankerson's kind of test is similar. However you mention performance, meaning also comfort during test, simplified to amound of pressure required to do so to eliminate handle comfort factor.
Seems a jig is required.
Having said that, for real EDU, handle comfort is important, so at the end, it's subjective.
PS: the K390 responded well to end grain cardboard strop + fresh autosolpractically shaved with it although not as smooth as the small paring 52100.
Chris "Anagarika";12876998 said:@hank,
Your question caused me to think further. Maybe wear resistance needs better definition. Cutting paper/cardboard is a continuous force applied to the apex. Cutting sand is one after another sand grain colliding with the apex thus maube this causing zdp to microchip?
@Bluntcut,
Really a good quest, perhaps need to relook at cutting other medium. Sandpaper might not be a good idea as the apex will also collide with the individual abrasive grain embedded to the paper.
Which brought us back to basic question : wear resistance against what substance and how to test.
K390: will test further. Maybe it's wire edge now but a tough wire![]()
Very interesting tests. I like the sand testing the best. It appears to be the most consistent.
I think we need to figure out a way to isolate and determine Abrasion Resistance and Toughness separately.
Also I think we need to have some small knives made that are all identical in size , thickness and edge geometry. And heat treated to the same impact resistance level (Based on the manufactures guidelines , say heat treated so that the blade has an impact resistance of 85ft/pds , based on crucibles toughness charts) And then all sharpened on a jig to matching finishes and angles. Say finish on Diamond or CBN loaded strops so that that carbide size is not a variable.
Again , I like your tests , but I feel that there are still some variables that make it inconclusive.
