Simple but tricky to make it work correctly. I’m known for making adapters for existing sheaths and this one needed something to make it carry better, for me at least. As the clip it came with had the handle of the knife too high to carry comfortably.
So I start by using a shop paper towel to make an approximate shape so I could use it to cut out the leather and then I will trim, and shape as needed for the final piece. Then get one hole in and then wrap the leather around tightly so as to mark the back side through the first hole so it will line up. And same with the second hole.
The knife is a Kizer Deckhand
Untitled by
GaryWGraley, on Flickr
It does have a large sharpening choil that I wish it didn't, eats up too much edge and also things catch on that sharp pointed corner, so I made it more of a ramp and angled the access upward so things don't catch quite as hard as before, it's better but marginally so.
The bobtail fob aids in drawing the knife, it has what's called a Wide Diamond knot which is also a tricky thing to tie.
Untitled by
The belt loop folds down and I skived the leather to blend it in and glued in place, there isn't any pressure or tension at this joining so it really doesn't need any stitching, it ain't going anywhere.
Untitled by
Felt odd marking the new year, but, I couldn't make 2024 last any longer
Untitled by
So, like I said, simple but tricky, kinda like leather origami. This now carries a lot easier over my right back pocket, easy to access and being kydex guiding the tip of the knife into the sheath is also fairly intuitive.
Welcome to 2025 folks
G2
edited to add one other bit that I modified on the sheath, there wasn't a good way to thumb break the knife out of the sheath as the kydex was made with a sloping section that your thumb would just slide up and over.
Untitled by
so I cut it down straight so at least you have a small wall to brace your thumb against in order to get the knife to be drawn easier.
Untitled by
