I would have to say that is an accurate comparison since I feel that Gordon Ramsay is an arrogant jerk who could use a belt in the mouth.
Back to what I asked just as this was going off topic, does ice water work to cool oil quenched blades? The ice water would have a slower quench than warm water, but much faster than oil. I'm just curious because I had thought about that for a while and just wondered if anyone knew an answer.
As to the ice water quench:
Room temp water quenches fast because, once that vapor jacket collapses, the cooling ability of water is very good. This brings down the steel temp faster than is desired often, resulting in warpage or cracking. Room temperature oil cools too slow because it has lower convection than warm oil.
Now, if you used ice cold water, it would not affect the vapor stage much at all ( maybe make it shorter?), and it would make a faster cooling curve for the steel once the jacket collapsed. To slow down water quench, you heat it up to near boiling. This however has other problems with a greatly prolonged vapor jacket due to the big change in the vapor pressure. So the best guidelines are use 120-130F oil, and 80-100F water.
Stacy
LMAO
As an esteemed economics professor once said "the market will decide..."
I just did a yahoo search for Ms in history and didnt get anything.
jake
In a subject like history it is more likely people wopuld get MAs. MS is a degree associated with science and engineering
