^^^[QUOTE="
Blade length over 3.75
Weight over 6oz
-Chiselgrinds. If I need a chisel, I'll use a chisel.
-Steels that are worse than 8CR13MOV, and even then it needs to have a funky design. So I've got a lot of CRKTs.
-half serrated blades
If someone wants a folder with a four-inch blade, why should they not be allowed to have one if it is legal to do so?
I'm curious, what is your attitude about firearms ownership?
Things i avoid in knives:
Chisel ground blades - I just don't see the point... not for me
Tanto points - they make the tip nearly impossible to use
Recurves with serrations - i don't like serrated blades in general
Digital camo handles - why make it harder to see if you drop it outdoors in the dark?
Deep carry pocket clips - i like easy access to my knife and I haven't lost a clipped folder yet
I'm sure there's more but right off the top of my head those are things I avoid when knife shopping.
One thing about liner or framelocks is that they are designed and easiest to use only in one hand, primarily a right hand unless a special run of 'left handed' models which are often not available but in just few instances. A lefthanded person would find the majority of liner and framelocks to be very difficult to close. Even a right handed person might not appreciate a knife that can't be easily closed by either hand. whereas a backlock is completely ambidextrous.
Grizz
What about a Tanto tip makes it difficult to use?
I actually love tanto tips. It’s almost like a wharncliffe with a kiridashi on the end.
There aren’t really any specs that are a turn-off for me. Almost any spec can be an appropriate property at a given price point. Sure, 3Cr sucks most of the time but for a $8 knife, not so much.
Maybe generic “surgical steel” always sucks...as well as “tactical speed holes in the blade to accommodate multiple zip ties”.
Those always are a turn off.
Pocket clips. Nothing worse than seeing one hanging out of someone's pants, especially a good pair of slacks.
It can put the tip in an odd place in relation to the center point of the off the grip thati is hard to use for precise cutting. For poking and stabbing they're great, but i don't poke or stab often.
