I'm eyeballin the #72 Grizzly. For all those who received a #72, is there any verticle play on lockup?
I have 2 #83's and both have verticle play. It actually bugs me when I hold the blade and do a "ring the bell motion vertically" and I hear clicking sounds. Is that repairable?
Anyways. the Grizzly is still beckoning but need more G2 on the lockup before I pull the trigger.
I just checked mine and it has just a tiny bit of vertical play, (micro). Not a problem for me but it's there.I'm eyeballin the #72 Grizzly. For all those who received a #72, is there any verticle play on lockup?
I have been smitten with the Queen #49 Cattle King and just ordered one in Stag Bone off of KSF:
That is gorgeous!!! How's the fit & finish and overall quality?
I've only just ordered it today. I'll give a full report when it comes in on Wed. The Queen City version that I picked up at their open house is fantastic, so my hopes are high.
Those certainly are an attractive stockman Cory. Ive eyed them on several of an occasion. Love the look of that stag bone.
I'm curious: how did you tweak the blade rub?
At the 14:37 mark of this video you can see Bill Howard fix the centering on a blade. He has what he calls a kick press that puts pressure on the tang, which is softened for this task, and that kinks the blade so that it's centered in the frame.
[video=youtube;xA-OpahW7EA]https://www.youtube.com/watch?v=xA-OpahW7EA[/video]
I don't have that press, but a while ago I had a knife with a blade that was rubbing the liner and I decided to see if I could simulate that process myself. What I did is put the blade into a padded vise so that the whole blade except for the tang is in the jaws of the vise. Then I push or pull the knife in the direction that would bend the blade to where I want it to be. It took a bit of practice to get a feel for how much pressure to apply, but I've gotten to be OK at it to where I usually don't have to go back and bend it the other way because I went to far anymore. This will loosen up the joint, so then I close the blade and put that end of the knife in the vise with a gapper inserted next to the blade tang and give it a squeeze to tighten it back up a bit. Then I usually have to hit the bolsters with some sandpaper because the pin is now showing.
It's not a really tough process, but it is a bit more involved than filing down the kick or something like that. I'm just a stickler for blade rub, and there was a knife I really liked other than the blade rub so I took a chance and it worked out. Now I can center the blades on most knives without too much stress. Some knives seem to have a tang that's just wonky and when I squeeze the bolster back together the blade moves back to being off-center again. I don't mind an off-center blade as long as it's not rubbing. I can usually at least get them to not rub. I'm sure there's a better way of doing all of this, but this is the method I came up with and it's worked for me.
