Leave it as-is, and you'll have a pretty decent first knife. Clean up the finish, and you'll have a really good-looking first knife.
-Tyson
Thanks! I read your comment too late though, LOL. I went back and wow! What a huge difference doing it properly. I'm much happier with it now.
Finished up this skinning blade for a customer today. It’s forged from a bar of 80crv2, fully tapered tang construction. Blade length is 4 1/4” with an OAL of 9”. It’s got rams horn scales, purple g10 liners, brass bolsters, and mosaic pins. The handle was left a little daintier than I would prefer, but it’s for a lady with smaller hands, so it was built to fit her.
Bummer :-(Been There, done that... But in this case what you see is about 1/2" less width after many trials, at this point I decided it wasn't worth extra time. I used it this weekend, its razor sharp, will be used, but not by a customer...
Pablo
Nice look. I wish you clocked those pins.Finished up this skinning blade for a customer today. It’s forged from a bar of 80crv2, fully tapered tang construction. Blade length is 4 1/4” with an OAL of 9”. It’s got rams horn scales, purple g10 liners, brass bolsters, and mosaic pins. The handle was left a little daintier than I would prefer, but it’s for a lady with smaller hands, so it was built to fit her.
Thanks. I tried. But I didn’t fit everything up before gluing and once I drove the pins in, they were to tight to turn, even with a pair of pliers.Nice look. I wish you clocked those pins.
Yeah, I understand, things can get hectic for me during glue-up.
Same here. I think next time all cut a groove in the ends of the pins and use a screwdriver to turn them.I actually do use a slow epoxy and I'm getting better at it, but making sure everything goes in the right places, and wiping everything repeatedly, changing gloves, clamps, it's still a bit of excitement.
At the risk of derailing the thread a little ... I learned the following from horsewright. With a knife with a bolster like that ... after the bolster is on, glue on ONE side of the handle, WITHOUT holes drilled into it. Allow to cure, then drill the holes through using the holes already in the tang . Glue on the second side of the handle (no holes in it). After curing, drill holes in the second side using the holes in the first side as a guide. If all holes, including the ones in the tang, are drilled one size over size , you should have little trouble with the pins . Personally, I leave the holes empty, rough shape the handle, take the handle finish to something like 200 grit, then glue in the pins (reaming the holes and peening if brass), then sand flush and continue finishing the handle.Thanks. I tried. But I didn’t fit everything up before gluing and once I drove the pins in, they were to tight to turn, even with a pair of pliers.
Not mine - Dave ferry’s.That’s a great idea! I’ll try that next time.
If you have to do this ^ you need to drill bigger holes!once I drove the pins in
