What's going on in your shop? Show us whats going on, and talk a bit about your work!
This arrived today! Now I need to build a stand for it and buy a forge and my home smithy will be off and running.
Went ahead and arbitrarily cut my 3-ft bar of magna cut into four 9 in pieces! It was actually a hard decision as I had been wanting to make a big Bowie!1652269303458.jpg
Went ahead and arbitrarily cut my 3-ft bar of magna cut into four 9 in pieces! It was actually a hard decision as I had been wanting to make a big Bowie!View attachment 1815158
I don't think the stock is thick enough for a Bowie, but I don't like that you've lost all flexibility for say one at 8" and another at 10". I'm sure you'll use it all anyway.
It's the first bar of "expansive" steel I bought. Also thinking about using the whole width and "crossing" the hidden tangs on the same part of the bar to maximize the use.
Freddy … I always struggle with that ā€œcrossing the tangsā€ idea. I have never found a way to cut the steel in that pattern with my ports saw … you just can’t make any kind of a tight turn without binding. Once I was able to drill a big enough hole to rotate the saw blade, but only once. Maybe one can be more successful with a cutoff wheel, but I don’t have one.
Mostly I just have to resort to a straight cut across the bar (and then cry at the waste of steel…
just about got this choil to where I want it this evening
proly hit it with some sandpaper tomorrow and call it good enough for ht, and then get back to taking that swedge down to zero
Hi Cush, I drill the holes on the tang side near the blade and make one cut between the tangs with an angle grinder and a quality 1 mm cutoff disk. To make the cut precise I clamp a piece of wood or micarta as a guide. With the guide you will get the nice cut, it is important to "cut inā€œ aggressively and with speed or the wheel will try to dance on the surface of the tang.
