Just finished these twin hunters.
OAL - 8.5” Edge - 4.5”
.09” 14C28N RC ~63 HT by Paul Bos
Dymalux handles - Cocobolo and Charcoal w/ fiber liners
Loveless style bolts and GFlex epoxy
Just need to make sheaths and put on final edge.
This is the way.I stack up the handle material scales, put the blade over them and then clamp all three pieces together. Then I drill my pinholes and add the pins. Then I Trace around the Tang and cut out the scales to the rough shape, including the front. With the pins still in the handle material, I shape and polish the whole front end of the handles before they ever go on the blade.
Thank you. This one was ground pre-HT. I had the same thought about some surface degradation, but I send my knives for HT to a professional facility that uses vacuum ovens, so I figured it is more likely my lack of skill rather than decarb or such. But I have another knife that I had to straighten and then grind a little post-HT, so I will try to see if the issue persists there as well.Are you grinding pre or post heat treat and are you heat treating them yourself? Any potential decarb/scale issue? I haven’t used that steel before but it doesn’t seem like grit should matter. Great looking knife by the way.
I've done it that way, but occasionally ran into problems if the scales weren't uniform thickness. Mostly with wood, micarta is the same thicknessThis is the way.
Q-Tips and alcohol. Shake off excess.Thanks for the tips. Always looking to improve. With these two the biggest factor was excess epoxy and the clean up of it. I still haven’t found a way, to my liking, of handling excess glue in this area. Sometimes tape works, I’ve tried wiping excess off but still leaves a film. I’m afraid of removing excess with alcohol/acetone while it’s setting up, due to possible harm to glue adhesion to handle slab/blade. Always a work in progress. Thanks again.
This too is the way.Q-Tips and alcohol. Shake off excess.
Understood. I used to have that problem but now I stick rough cut wood pieces on my SGA with double sided tape and even them up before I use them.I've done it that way, but occasionally ran into problems if the scales weren't uniform thickness. Mostly with wood, micarta is the same thickness
What epoxy do you use? It helps to use something with a longer set/cure time if you aren’t already. Myself and every maker I’ve ever talked to used either alcohol or acetone on q-tips to clean that area up and I haven’t heard of anyone having trouble. They both evaporate so quickly I’d say the risk is minimal. I removed the handles of one of the knives I made using that cleanup method and essentially had to burn the g10 liners off of the tang with a torch. I use G-flex epoxy by the way.Thanks for the tips. Always looking to improve. With these two the biggest factor was excess epoxy and the clean up of it. I still haven’t found a way, to my liking, of handling excess glue in this area. Sometimes tape works, I’ve tried wiping excess off but still leaves a film. I’m afraid of removing excess with alcohol/acetone while it’s setting up, due to possible harm to glue adhesion to handle slab/blade. Always a work in progress. Thanks again.
I use pointed q tips which work really well. It has a standard tip on one end, a pointed one on the otherWhat epoxy do you use? It helps to use something with a longer set/cure time if you aren’t already. Myself and every maker I’ve ever talked to used either alcohol or acetone on q-tips to clean that area up and I haven’t heard of anyone having trouble. They both evaporate so quickly I’d say the risk is minimal. I removed the handles of one of the knives I made using that cleanup method and essentially had to burn the g10 liners off of the tang with a torch. I use G-flex epoxy by the way.
G10 is glass and scratches hardened steel (guess how I found out)I’ve recently sharpened a piece of G10 liner to use as scraper which seems to be working well. These two got away from me. I have to pay more attention at final fit. Thanks all!
I use GFlex also. My experience with alcohol/acetone clean-up has to do with my work. I work on medical/ophthalmic lasers. I’ve had alcohol/acetone migrate into places that caused issues with bonding etc. Obviously, amount of surface area glued comes into play. I’ll definitely start the alcohol clean up to save trouble down the road. Thanks againWhat epoxy do you use? It helps to use something with a longer set/cure time if you aren’t already. Myself and every maker I’ve ever talked to used either alcohol or acetone on q-tips to clean that area up and I haven’t heard of anyone having trouble. They both evaporate so quickly I’d say the risk is minimal. I removed the handles of one of the knives I made using that cleanup method and essentially had to burn the g10 liners off of the tang with a torch. I use G-flex epoxy by the way.
Makes sense. I used one damp q-tip and a shop towel to clean up 4 knives I glued yesterday so it really doesn’t take much. The instructions for G/flex 650 call out using a citrus based cleaner, acetone or lacquer thinner to clean up epoxy residue. I’d probably avoid citrus based as it might etch/oxidize the metal.I use GFlex also. My experience with alcohol/acetone clean-up has to do with my work. I work on medical/ophthalmic lasers. I’ve had alcohol/acetone migrate into places that caused issues with bonding etc. Obviously, amount of surface area glued comes into play. I’ll definitely start the alcohol clean up to save trouble down the road. Thanks again
