There is a real emphasis in some circles on widening the swath which practically limits the depth of cut, but does not affect the size of the windrow. Most of the time, I actually limit or even reduce the width of the swath somewhat, as heavy grass can be deposited into a workable windrow that under good conditions can dry without spreading. This becomes a big help with larger volumes of hay, as spreading/turning is more work than cutting as handling increases. Also, if there are good clovers such as Ladino in the mix, you have to be careful about drying too far too fast or manipulating more than necessary. Most of this is dependent on local conditions, for example I do not cut as early as some, as the dew is generally too heavy. The grass cuts well mid morning and late evening, though, but is not wet enough to need spreading, and the ground between rows needs to dry. With optimum setting, then, an equal rate of cutting with reduced width can realized by taking bigger bite
As you imply, however, limiting depth of cut and making it redundant may not be a bad idea for mowing lawns, clearing weeds, or even cutting light hay. It will allow beginning users to cut the expected swath width cleanly, but prevent them from biting off too much.
